I try to make a 30 V, 5 A power supply using LM338 (without heatsink) voltage regulator IC.
In my case the value of R1 is 100 Ω and R2 is 2.2 kΩ. then it gives 29.6 V as output.
when we connect a 10 Ω 10 W resistor, the current is exceeded 1 A, the IC gets hot within a few seconds output current and voltage become zero. (I think the IC thermally shuts down).
After cooling the IC when we reconnect power then we got no output voltage and no current, IC is also not getting hot.
we can't conclude why it's happening. Is Ic got damaged?
After that, we did one more experiment.
Constant Current Circuit as given in the datasheet.
In my case R1 = 10 Ω, 10 W and load is again 10 Ω 10 W.
Here again within few seconds no output voltage and current.
