I have a circuit with many components for which I need to find the transfer function. More precisely, the circuit I am looking at looks something like that:enter image description here
Please don't go into the trouble of computing this transfer function, I just want the general methodology that one would follow as I will later use a code which will do all the tedious mathematics for me. That being said, my professor keeps telling me that I need to use the formula \$H = \lvert \frac{Z_2}{Z_1 +Z_2}\rvert\$ which is quite easy to use when I have a simple RC filter but when all of these components are included, I am lost.
Should I just start from the end and just keep adding impedances? For instance, say:
$$Z_a = ((Z_{C_5} + R_4) || Z_{C_4}) + Z_{L_2} $$
Then:
$$Z_b = (Z_a||Z_{C_3}) + R_3 + R_2 $$
Similarly:
$$Z_c = (Z_b||Z_{C_2}) + Z_{L_1}$$
And finally:
$$Z_d = (Z_c||Z_{C_1}) + R_1$$
Hence:
$$H = \frac{Z_c||Z_{C_2}}{Z_c||Z_{C_2} + R_1}$$
Where \$Z_{C_n} = \frac{1}{j\omega C_n}\$ and \$Z_{L_n}=j\omega L_n\$
Would something like that, in theory, give me the appropriate transfer function? If yes, then it's easy enough to code this. However, as I lack experience with these type of systems, I am not sure whether my method is appropriate. Any feedback or edits to the question to make it clearer are always much appreciated.
  • \$\begingroup\$ You have forgotten that an inductor has a reactance and that it is dependent on frequency. Ditto capacitors. Reactances and resistances are paralleled or added i.e. you can't simply add C5 and R4 because that is nonsense; farads plus ohms is meaningless. \$\endgroup\$
    Nov 26, 2020 at 11:56
  • \$\begingroup\$ I am aware of that. In the above equations, when I write C or L, I am actually referring to 1/(jwL) and jwL respectively. I will edit my question so that it is clearer. \$\endgroup\$
    – Matthew H
    Nov 26, 2020 at 11:59
    \$\begingroup\$ @MatthewH thanks! I don't know about your place, but at my uni, writing L when one means \$j\omega L\$ would be marked as mistake, so it might be a good idea to avoid that. If you want to write down complex-valued components with a single letter, \$Z\$ or \$X\$ might be what you're looking for in your material. \$\endgroup\$ Nov 26, 2020 at 12:00
  • \$\begingroup\$ Thanks for your feedback, I am editing at the moment. \$\endgroup\$
    – Matthew H
    Nov 26, 2020 at 12:01
  • \$\begingroup\$ Maybe consider using transmission matrices for accumulating the effect of several multipally connected components. youtube.com/watch?v=NaohbrlLZoQ \$\endgroup\$
6
This circuit is a 7th-order system and if you apply the impedance divider as recommended, then you'll end up in a total algebraic paralysis unless you want to use a computer for doing it. If you want to derive by hand and express it in a readable polynomial format, the best is to apply the fast analytical circuits techniques or FACTs, they are unbeatable in passive circuits like the one you shown. I have published a book on the subject and an introductory seminar in 2016.
The principle is quite simple, you have to determine the time constants of the circuit in two conditions: with a zeroed excitation you obtain the poles of the circuit and when the response is nulled you determine the zeroes of the transfer function. By inspection for instance, I can see there are no zeroes in your circuit, only poles.
As an example, I have derived a 6th-order transfer function and the circuit was that one below:
There are no zeroes either in this one. So after zeroing the excitation (the voltage source is replaced by a short circuit), you temporarily remove each energy-storing element and determine the resistance \$R\$ "seen" from its terminals. That resistance is then combined to form the time constants you need: \$\tau=RC\$ and \$\tau=\frac{L}{R}\$. This is what is shown below:
What is cool is that you inspect the circuit and don't write a single line of algebra which avoids mistakes. The good thing is that you can come back to these little sketches later if you spot a mistake: just fix the guilty sketch without restarting from scratch. It saved me many times : )
As you go up in the terms, it becomes a bit more complicated but the principle remains the same: a sketch from which you can infer the time constants while the elements are either shorted or open-circuited:
Once done, you can use the method you want to determine the transfer function with a brute-force approach as a reference function. I personally favor Thévenin but you could use any other one. With Mathcad, there is no need to develop the expressions which is good:
Then, you can plot the response obtained from this approach and compare it with that given by the FACTs. As you can see, the format is already in an ordered form where all coefficients are individually determined:
If you carefully determined the time constants, then the error between the brute-force approach and the FACTs should be in the solver noise, in the pico range:
I obviously won't encourage you to go straight to solving a 6th or 7th-order circuit with the FACTs. But the method is truly an extraordinary tool and once you've acquired the skill, you won't go back to the classical method. Start with simple first-order circuits and increase complexity until you master the method. Then, you can jump on more complicated circuit as yours. Good luck!
    \$\begingroup\$ Thank you, correction done. \$\endgroup\$ Nov 27, 2020 at 6:26
... my professor keeps telling me that I need to use the formula \$H = \lvert \frac{Z_2}{Z_1 +Z_2}\rvert\$
This is what's called a ladder filter. There's a series element, then a shunt element, then series, then shunt and so on, from one end to the other. That equation of your Prof is fine, but you'll have to iterate it for each series/shunt pair in the filter.
I won't say that this is easy. It's never easy for me, as by the time I've ground through all the equations I'm guaranteed to have dropped a term somewhere, but it is straightforward. Which means you can just simply repeat the same method, which is quite easy to code up if you want to do that, again and again until you have accounted for all the components, series/shunt pair by series/shunt pair.
Starting at the output, write Vout = V(C4) * ZC5 / (R4+ZC5).
Now you need to know V(C4)
V(C4) = V(C3) * Z(C4&R4&C5) / (ZL2+Z(C4&R4&C5))
In this way you can track your Vs all the way back to the filter input.
Note that in this last step, you need Z(C4&R4&C5), which is also straightforward to calculate.
When you come to evaluate V(C3) as a function of V(C2), you will need to use Z(C3&L2&C4&R4&C5), which looks horrible by itself, but you have already calculated Z(C4&R4&C5) in the last step, which is a component of it.
In this way you can track all of your shunt impedances back to the input of the filter. Keep going from output back to input, and by the time you get to the input you'll have a honkin' great equation in \$j\omega\$ and a lot of constants.
