I have an existing circuit powered with a 3.7V LiPo battery. To indicate when the battery is under 3V, I wanted to add an LED which shows me to charge the battery.
The circuit has to be very small.
I searched for circuits on the internet but they mostly had rather complicated circuits and not suited for my system. I need it to show me only when the battery is under 3V. It doesn't need to be adjustable. What would the circuit look like? I saw many circuits with ICs and transistors. I didn't get how to choose the right components for my task.
    \$\begingroup\$ The LED will add a load to the rapidly depleting battery and accelerate it towards full discharge so wouldn't a flashing led (50:1 duty cycle) be better i.e. on for 0.1 seconds and off for 5 seconds? \$\endgroup\$
    Nov 27, 2020 at 9:57
    \$\begingroup\$ Far more foolproof to have the LED flash to show the battery is ok like they do with smoke alarms. \$\endgroup\$
    – Finbarr
    Nov 27, 2020 at 10:30
Here is a basic circuit that you can adjust with R1 when you want your LED to light up when the voltage decrease.
  • D1 is a Zener diode, you can use something between 1-2.5V with low leakage.
  • R1 is a trim-pot that you can adjust.
  • OA1 needs to be chosen to fit your supply range and has enough current output to supply the led.
  • Use a low current LED like 1-2mA.
  • You can add an NPN transistor after OA1 if you need more current for the LED.
  • R2 has to be big enough not to deplete the battery, but small enough so that the leakage current of D1 is not significant.
As already mentioned in the comments, in order to save power you could make use of a flashing LED which is activated if the battery voltage drops below 3V.
Here is small simulation:
circuit
Basically it consists of a 2.5V reference voltage (TL431) and a small logic for turning the astable multivibrator circuit on and off.
How it works:
If the supply voltage is above 3V
  • The cathode end of the TL431 will pull the gate of \$M_2\$ to ground
  • Fet \$M_1\$ and \$M_2\$ will be turned off
  • Astable multivibrator is disconnected from the supply
  • Quiescent current is very small
If the supply voltage is below 3V
  • The cathode end of the TL431 acts as a open collector
  • Fet \$M_1\$ and \$M_2\$ will be turned on
  • Astable multivibrator is connected to the supply
  • The frequency at which the LED flashes can be adjusted by capacitors \$C_1\$ and \$C_2\$ and resistors \$R_9\$ and \$R_8\$.
If you really want to keep the LED on all the time, you could replace the multivibrator with a joule thief circuit, but it causes the battery to be depleted rather quickly:
circuit_2
