I wrote the following code:
module mul3 (
    input logic[1:0] d
mul3_op[0]=d[0];
endmodule;
But when I run it using Modelsim I get the following messages:
Error: (vlog-13069) mul3.sv(21): near "[": syntax error, unexpected '['.
Error: mul3.sv(21): (vlog-13205) Syntax error found in the scope following 'mul3_op'. Is there a missing '::'?
Please note that line 21 is actually the last line before endmodule in the code above. Any idea of what is wrong?
  • \$\begingroup\$ Mybe "input logic[1:0] d," and "output logic[3:0] res" should be "input [1:0]logic d," and "output [3:0]logic res". \$\endgroup\$
    – Arseniy
    Commented Nov 27, 2020 at 12:24
  • \$\begingroup\$ @Arseniy what I wrote is correct; input appears before \$\endgroup\$ Commented Nov 27, 2020 at 12:27
    \$\begingroup\$ You missed 'assign' before that statement. \$\endgroup\$
    – Mitu Raj
    Commented Nov 27, 2020 at 12:35
  • \$\begingroup\$ why I need assign? \$\endgroup\$ Commented Nov 27, 2020 at 12:37
    \$\begingroup\$ Because that's the standard syntax. \$\endgroup\$
    – Mitu Raj
You missed assign keyword for that concurrent statement -
assign mul3_op[0] = d [0] ;
  • \$\begingroup\$ Do I need assign too if I wrote: "mul_enable[1]=mul;" \$\endgroup\$ Commented Nov 27, 2020 at 12:42
    \$\begingroup\$ Any assignment outside the always block need the "assign" word. \$\endgroup\$
    – Arseniy
    Commented Nov 27, 2020 at 12:46
    \$\begingroup\$ Yes if it's a continuous assignment, ie., outside always/initial blocks. \$\endgroup\$
    – Mitu Raj
    Commented Nov 27, 2020 at 12:47
