I am designing a digital output circuit.
I got confused about the position of the current limiting resistor of the transistor.
I would like know where it should be. (After or before the pull up resistor.)
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityI am designing a digital output circuit.
In your circuit, U23 is not a source of current into the Q25 base; it works by shunting base current away from the transistor. The base current is supplied solely by R110, so it's value should be calculated to deliver the current required to saturate the transistor.
In fact, R109 should be removed because it hurts the circuit. When U23 is on, R109 and R110 form a voltage divider, so the Q25 base voltage never is below (0.46 V + U23 Vcesat). This is not low enough to guarantee that Q25 turns completely off. Assuming Q25 has a nominal gain of 100, it takes only 50 uA of base current to drive it into light saturation.
It makes no sense on either before or after the pull-up and can be removed.
That circuit will not work as expected. Resistor R109 and R110 makes voltage divider and Vbase of Q25 never lower whan 0.7 V. So Q25 is on all time. You may put R109 after R110, it will work, but not really nessesary.
