I recently start to read the dissertation of Dr.Ridley, A New Small-Signal Model for Current-Mode Control and I am stuck on a basic equation.
First we have the function of the inductor current for constant frequency control : $$ R_i<i_L>=v_c-DT_sS_e-\frac{S_fD'T_s}{2} $$
Which is fine, I get it, then the equation below can be describe : $$ D=\frac{v_{off}}{v_{on}+v_{off}}\\ D'=\frac{v_{on}}{v_{on}+v_{off}}\\ S_f=\frac{v_{off}R_i}{L} $$ Normally, if I substitute theses equations in the previous function and perturbing the ON-time voltage, I should get this : $$ \frac{<\hat{i_L}>}{\hat{v_{on}}} = \frac{DS_eT_s}{V_{ap}R_i}-\frac{D^2T_s}{2L} $$ But I can't. I guess I'm missing something but I don't know what. Do you have any idea ?
EDIT : Here's what I can get : $$ <i_L>=-\frac{DT_sS_e}{R_i\hat{v_{on}}}-\frac{D(V_{on}+\hat{v_{on}})T_s}{2L\hat{v_{on}}} $$
\$T_s\$ is the period of the switching frequency, \$D\$ the duty cycle, \$R_i\$ the current sense resistor, \$v_{on}\$ voltage when switch is ON, \$v_{off}\$ voltage when the switch is OFF, \$v_c\$ is the control voltage. As for \$S_f\$ it's the current slope inductor and \$S_e\$ is the slope compensation of the voltage control as seen below :
    \$\begingroup\$ You might choose to fully explain what all the formula symbols represent because you certainly can't rely on the linked document for doing that. \$\endgroup\$
    Nov 27, 2020 at 15:15
  • \$\begingroup\$ Where are you stuck ? Are you able to get the first equation which has three terms down to two terms ? The last terms of both the equations seems to be direct substitution. Please explain in detail where you are stuck. \$\endgroup\$
    – AJN
    Nov 27, 2020 at 15:31
  • \$\begingroup\$ Ok I edited my question. \$\endgroup\$
    – Gontran
    Nov 27, 2020 at 19:01
There are different ways to obtain a small-signal equation from a large-signal one. The expression \$R_i<i_L>=v_c-DT_sS_e-\frac{S_fD'T_s}{2}\$ is a large-signal one and describes the current leaving terminal c in the PWM switch model scaled by the sense resistance \$R_i\$. You can either perturb each of the variables and then sort out dc and ac equations, the latter being the one you want. The other option - which I always use - is partial differentiation.
The equation in question is a function of the duty ratio \$D\$. If you replace \$D\$ by the expressions you gave, you obtain: \$I_L=\frac{v_c}{R_i}-\frac{v_{off}}{v_{on}+v_{off}}T_s\frac{S_e}{R_i}-\frac{\frac{v_{off}R_i}{L}(1-\frac{v_{off}}{v_{off}+v_{off}})}{2R_i}T_s\$. So this function depends on \$v_c\$, \$v_{on}\$ and \$v_{off}\$. If you consider \$v_c\$ and \$v_{off}\$ ac-silent (their derivative is 0), then you can differentiate \$I_L\$ with respect to \$v_{on}\$ and obtain:
Factor the on- and off-voltages to reveal the duty ratio \$D\$ again. You see that a term remains and this is \$(v_{on}+v_{off})\$. If you look back at the PWM switch model, you realize that the dc on-time voltage is labeled \$V_{ac}\$ while the off-time voltage is labeled \$V_{cp}\$. Therefore, substituting these values in the on and off sum leads to: \$V_{on}+V_{off}=V_{ac}+V_{cp}=V_{ap}\$. It leads to:
If you carry on the exercise, you obtain the invariant gain \$k'_f\$ as follows:
You can now repeat the exercise for \$k'_r\$. If you want to simulate the entire model, there you go:
As you can see from the above, Ridley's model cannot find its dc operating point and is therefore constrained to ac simulations only. If you want to explore transient simulations with a current-mode model, I would recommend Vatché Vorpérian's version which predicts sub-harmonic oscillations with only two current sources. It is unbeatable in terms of simplicity. It has been extensively described in the book I published (with an original auto-toggling CCM-DCM model) but also through many APEC seminars (2013 and 2014) I taught.
