I've been doing a lot of research into linear actuators, and have come up pretty much empty handed in finding any small sized (lifting force 10-30 newtons) linear actuators for a doable price (30-50 dollars). I've seen some diy rack and pinion designs, and while prototyping I ended up turning a servo into a linear actuator with a lift arm, but I'm not much of a machinist, and would much rather a all in one solution.
So does anyone know of anywhere that sells 30-50 dollar linear actuators? Or will I always need to make them myself?
closed as off-topic by Matt Young, RedGrittyBrick, Daniel Grillo, Chetan Bhargava, Nick Alexeev Jan 15 '14 at 17:07
This question appears to be off-topic. The users who voted to close gave this specific reason:
If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ This is a mechanical engineering question, without much of electrical engineering aspect, which this site is about. Also, it is a request for a shopping recommendation, and those are frowned upon here, unfortunately. I'm sure some of us are tempted to answer it, nevertheless! \$\endgroup\$ – Anindo Ghosh Jan 9 '13 at 7:30
    \$\begingroup\$ DIY can be easyish depending on required lifetime. Nut on a thread can give you a reasonable reduction ratio.Worm drive to gear gives you N:1 for an N tooth gear and a 1-start worm (which almost all will be). \$\endgroup\$ – Russell McMahon Jan 9 '13 at 15:05
(1) Nut on a thread can give you a reasonable reduction ratio.
If this is for one off or a few and depending on size then battery-drill motor plus gearboxes driving a threaded rod may work for you. [I'm lifting ~= 100 kg using these so your 30 N figures is easily met :-). Battery powered screw drivers can also be used. As a screwdriver is usually of lower gearing you could use a linear linkage from a "con rod" directly off a driven wheel of desired size to get the travel you need.
An example
Ha ha / Wow Pet feeder linear actuatoir using a RC servo
Instructables RC servo based - low speed linear feed- OK for ideqas.
(2) Worm drive to gear gives you N:1 for an N tooth gear and a 1-start worm (which almost all will be). Driven gear to "con rod" gives linear output.
Search for "door lock actuator". If you don't mind closing your own control loops externally (current/position), then automotive power door lock linear actuators are a great way to get a compact linear actuator at a low price (provided that you don't need much mechanical reduction)
  • \$\begingroup\$ Just ordered a few in to play with, thanks for the suggestion :) \$\endgroup\$ – Ben Jan 10 '13 at 0:28
You don't give much in the way of specs beyond force, but I suggest peeking at Firgelli Technologies. They're not quite in your price range, but not all that far off, and they can be ordered with a few different control interfaces. It feels like a fair price.
