I am producing a PWM pulse of say 5Mhz from one of the pin of PIC micrcontroller and I want to drive this to high speed buffer, what is the best way to transfer this RF current from the pin of uC to the pin of buffer? Do I need some kind of wave guide/microstrip or a small stranded wire would do? Can I use Litz wire for this? The distance between uC and buffer is very short.
  • \$\begingroup\$ Wire. PCB track. Anything. :-) \$\endgroup\$ – Anindo Ghosh Jan 9 '13 at 9:56
    \$\begingroup\$ Note that it is not the (base) frequency of your signal, but the spectrum of it, or put in another wording: the waveform, especially the rise and fall times. If you don't care too much about those, 5 MHz is quite low. If you care about the waveform, you must establish up to which higher frequency components (harmonics) you want to preserve. \$\endgroup\$ – Wouter van Ooijen Jan 9 '13 at 10:41
5MHz is a very low frequency and I doubt You can call it RF... Such frequency signal requires no special routing.
| improve this answer | |
