Lower the resistor even more.
You appear to have the 3.3V version of the Arduino Pro Mini. It should be able to supply much more current than you need.
The problem is the low voltage. A green LED needs about 2.5 volts to light up. A typical green LED can handle about 20 milliamperes of current.
You have a 3.3V output. Take away the 2.5V for the LED. That leaves 0.8V to drop across the resistor. With that 200 ohm resistor, you are getting about 4 milliamperes.
If you use a 40 ohm resistor, you will get around 20 milliamperes through the LED - that should be much brighter.
You figure LED resistors like this:
$$R = \frac {V - V_f}{I_{LED}} $$
Where:
- \$R\$ = series resistor (in ohms)
- \$V\$ = source voltage (in volts)
- \$V_f\$ = forward voltage of the LED (in volts)
- \$I_{LED}\$ = desired current through the LED (in amperes)
You need to know the forward voltage of your LED, and the maximum allowed current for your LED. Use the above formula to calculate the smallest allowed resistor. Try your circuit with that smallest resistor. If it is too bright then you can use a larger resistor. If it isn't bright enough then you need a different LED.
Use a voltmeter to check the GPIO pin when the LED is on. Make sure that it really reaches 3.3V. Try it with the LED connected, and without the LED. The voltage should be the same. If it is lower when the LED is connected then you are drawing too much current from the pin - in that case you will have to use a transistor to switch your LED.
Some LEDs are just not all that bright. Modern ones are really efficient and can be eye searingly bright at the rated current - you can usually drive them with just a milliampere or less and still be able to see it in daylight . Old ones from like the 1970s weren't that good. It took the full rated current to be visible in normal room lighting. Maybe you just got a really dim LED from the dark ages. :)
