I have a question regarding Xilinx Vivado. I don't really know how to explain it, but I'll give it a try and hopefully you will know what I mean.
In Vivado, you can instantiate primitives for example an IDDR. I need 15 IDDRs, is it enough when I instantiate one? The instantiation looks like this:
  IBUFDS_inst : IBUFDS
   generic map (
      DIFF_TERM => FALSE, -- Differential Termination
      IBUF_LOW_PWR => TRUE, -- Low power (TRUE) vs. performance (FALSE) setting for referenced I/O standards
      IOSTANDARD => "DEFAULT")
   port map (
      O => O,  -- Buffer output
      I => DIN1P,  -- Diff_p buffer input (connect directly to top-level port)
      IB => DIN1N -- Diff_n buffer input (connect directly to top-level port)
But I also need IDDRs for DIN2P, DIN2N till DIN15P,DIN15N. Do I have to instantiate this component 15 times?
  • \$\begingroup\$ Think of each instantiation as a virtual device on a virdual PCB. The value before the ":" is the reference designator, and the IBUFDS is the part number. You would need 16 buffers on a real board, so you need 16 buffers in your VHDL as well. You can use a generate statement to create them all at once to save some typing. \$\endgroup\$
    – crj11
    Nov 29, 2020 at 22:43
  • \$\begingroup\$ @crj11 so I can just call them IBUFDS_inst : IBUFDS1 and so on? \$\endgroup\$
    – Yoomo
    Nov 30, 2020 at 12:21
    \$\begingroup\$ The correct format would be BUF1 : IBUFDS, BUF2 : IBUFDS, BUF3 : IBUFDS ... The BUFx is the equivalent to the reference designator on a schematic and IBUFDS is equivalent to the part number. \$\endgroup\$
    – crj11
    Nov 30, 2020 at 13:12
  • \$\begingroup\$ Thanks I used the generate statement at it works. Doing it like "BUF1 : IBUFDS, BUF2 : IBUFDS, BUF3 : IBUFDS" gave me errors \$\endgroup\$
    – Yoomo
    Nov 30, 2020 at 13:58
  • \$\begingroup\$ I guess I should have been more specific. The format is BUF1 : IBUFDS <generic map + port map>; BUF2 : IBUFDS <generic map + port map>; BUF3 : IBUFDS <generic map + port map>; . The commas were meant to imply a sequence of instantiations. \$\endgroup\$
    – crj11
    Nov 30, 2020 at 14:02
The best way to instantiate multiple repetitive structures such as multiple IBUF is with the for generate statement. Here is an example for the above IBUF.
IBUFDSgen: for i in 9 downto 0 generate --instantiates 10 IBUFs
   generic map (
   port map (
      O => O(i),  -- Buffer output
      I => DIN1P(i),  -- Diff_p buffer input (connect directly to top-level port)
      IB => DIN1N(i) -- Diff_n buffer input (connect directly to top-level port)
end generate IBUFDSgen;
