What is the mathematical relationship between the switching frequency of MOSFET in a three phase motor controller (induction motor and BLDC motor) and the speed in rpm of the motor shaft?
  • \$\begingroup\$ In a BLDC motor drive, there are two switching frequencies: the commutation frequency, and in most drive methods, a higher frequency switching with the goal of effectively applying less than the full supply voltage to the windings. There is also a third possibility: some BLDC motors with an integrated controller receive a speed or torque input through a PWM signal. Which are you asking about? \$\endgroup\$ – Phil Frost Jan 9 '13 at 16:08
There isn't one really.
The switching frequency of the MOSFETs is a function of the inductance and resistance of the motor and is used to control current ripple (and therefore torque ripple).
The speed of the motor shaft is a function of how fast you change which of the three phases are being powered.
That being said, there are limits. For instance the switching losses incurred from a high switching frequency will limit the amount of power available to the motor and therefore limit the speed with which you can commutate the motor.
