I have recently faced a problem...whenever I mirror my pcb by using the shortcut>>M+i all of the tear drops which are defined in my design will be disappeared! does anyone know why this problem happens??
thank you in advance!
  • \$\begingroup\$ Have you tried the altium discord site - it's pretty active. \$\endgroup\$
    Commented Dec 1, 2020 at 18:00
Teardrops in Altium are not treated as primitives; instead they are a sort of post-processed element that's added on top and is never really merged with the routing. When you move a trace that has a teardrop on it, that element vanishes because the original location for it has changed. Not knowing how their code is written I don't know how else to describe it. At this point I don't really have a workaround, except to simply apply the teardrops at the very end of your routing process.
  • \$\begingroup\$ you really did me a favor👌 \$\endgroup\$
    – mahsa
    Commented Dec 1, 2020 at 19:24
