I'd like to add Rser into my V1 like in the image below, but I couldn't find how to do it. I checked the internet, looked at ngspice's manual. I tried adding resistance next to V1 but PP value of out1 reading is 10 although it should be ~9.98 which was measured in LTspice
I appreciate any help. Thanks!
Rser
? Have you compared LTspice's reading usingRser
versus LTspice's reading using an explicit resistor? Also, why are you assuming ~9.98V is correct? \$\endgroup\$ – Ste Kulov Dec 2 '20 at 7:55Rser
is specific to LTspice (though other simulators may implement parasitics, as well). Ngspice doesn't have parasitics (you said you looked in the manual). "I tried adding resistance next to V1" -- was it series or parallel? \$\endgroup\$ – a concerned citizen Dec 2 '20 at 8:10
