I need some help identifying the component in the picture above. It is a step-up DC/DC converter. Input is approximately 5V from USB converted to +/- 6.8V. It is used in Micsig’s differential probe. Google search for “AH4V55V5S-1W” only refers me to eevblog. I looked at websites such as RS and mouser and could not find anything similar. Usual output voltages are 5V, 9V, 12V.
1\$\begingroup\$ I suspect it's got an in-house part number, and was sold only to Micsig for their probe. Those things are modules, with a plain ol' circuit board potted into a case, so it wouldn't be hard for the manufacturer to change the output voltage setting on a standard product. \$\endgroup\$– TimWescottDec 2, 2020 at 17:16
\$\begingroup\$ Thank you for your reply. I only require a single unit so I do not think any changes to the product would be possible. I will investigate the rest of the board and see if it can handle +/- 9V as +/- 5V could degrade the performance (all voltage rails to op-amps drop). \$\endgroup\$– WintermuteDec 10, 2020 at 10:13
