To achieve a certain value of the magnetizing inductance (Lm), we can adjust the transformer air gap.
Air gap calculation formula:
There is no particular information on this, but I assumed that:
u0 = Vacuum permeability (4π×10−7 H/m)
N - primary turns? (x18)
Ae effective area (PQ5050) = 328mm2 (Core datasheet)
Lm = magnetic inductance (my goal - 60uH)
Substituting these values into the formula, I got 2.2 meters of the gap, which is clearly incorrect.
(0.000001257 * 324(18^2) * 0.328) / 0.00006
Next, I tried replacing N with the transformation ratio (n = 1.5), I got 15.46mm of the gap. This is closer to true, but still a very large gap.
(0.000001257 * 2.25(1.5^2) * 0.328) / 0.00006
I also tried to remove the square from N, but this is still a very large gap.
Question: what is my mistake? I assumed that the matter is in N (it is not clear whether this is the number of turns of the primary winding, or this is the transformation ratio (but it is denoted by a small n))
Perhaps there are other formulas with which you can get the Air gap value, the desired value of the magnetizing inductance?
