I desiged P-MOSFET for reverse voltage protection, without gate resistor.
The reason that I tend to use it is protect from reverse DC voltage when someone connects the battery. Do I need a gate resistor? (When someone connects the battery correctly it will be in the ON state, otherwise the PMOS will be OFF.)
Second question:
How does a gate resistor reduce ringing?
  • \$\begingroup\$ Show your schematic design; embed an image so everyone knows exactly what you are talking about. Battery voltage range and output current range values are needed. \$\endgroup\$
    Dec 3 '20 at 11:33
  • \$\begingroup\$ its a simple voltage circuit protection with dc input that could connect from ATX Power supply(12v) its okay for datasheet... @Andyaka \$\endgroup\$
    – Knowledge
    Dec 3 '20 at 11:49
  • \$\begingroup\$ Does this answer your question? \$\endgroup\$ Dec 3 '20 at 13:37
  • \$\begingroup\$ electronics.stackexchange.com/questions/287792/… \$\endgroup\$
    – JonRB
    Dec 4 '20 at 10:16
-3
Does a MOSFET gate resistor reduce ringing?
No a MOSFET gate resistor doesn't reduce ringing.
Ringing is an unwanted oscillation of a voltage or current. It happens when an electrical pulse causes the parasitic capacitances and inductances in the circuit to resonate at their characteristic frequency.
It depends on the VGS of your mosfet if the applied voltage and current is higher than it rated for YES you should add a resistor if not you don't have to. With a resistor or without your mosfet is always on.
what you are trying to do is well described here
  • \$\begingroup\$ Gate stopper resistor sometimes helps to dampen the oscillation/ringing. \$\endgroup\$ Dec 3 '20 at 13:38
  • \$\begingroup\$ @RohatKılıç A low pass filter is more promising, but it depends the cause of the ringing. \$\endgroup\$
    – autodidact
    Dec 3 '20 at 13:52
    \$\begingroup\$ -1 this answer implies that if you add a gateresistor you can drive the gate with a higher than rated Vgs. Incorrect, of you overvoltage the gate you damage the gate. Could you use a voltage divider ? Yes but there would also be issues. A gate resistor should always be added, at the very least it helps prevent creating a Pearce oscillator. Likewise control the current flowing into the gate \$\endgroup\$
    – JonRB
    Dec 3 '20 at 14:43
    \$\begingroup\$ Also a gate resiator can reduce ringing (on Vgs and Vds) \$\endgroup\$
    – JonRB
    Dec 3 '20 at 14:44
  • \$\begingroup\$ As the gate has capacitance, adding a series resistor creates a low pass filter. That's why it can help reduce ringing. \$\endgroup\$
    – Finbarr
    Dec 3 '20 at 14:55
