When bluetooth was first devised there was typically only one device to connect to at a time so it was quite natural to just implement a pairing protocol. I believe we are now on Bluetooth 5
Why is it that:
- Each device may typically only pair with a single other device?
- Even in devices that have multiple bluetooth capable chips only one is used.
- In contrast with the profileration of usb hubs there are very few bluetooth hubs on sale and they are relaitvely expensive (e.g. the CASSIA which seems to have been discontinued)
I note that there is now "dual audio". Allowing you to pair with up to 3 (which is more than dual!) audio devices but this is not what I'm after.
Referring to this article one bluetooth master can support up to 7 slaves.
However if we consider some basic IoT scenarios this does not match the requirements very well. Consider:
I have one or more bluetooth speakers in my home
- I would like to be able to send music to one from any device:
- My phone
- My partners phone
- A PC
- Without having the speaker or the audio source forget the previous connection.
- Only one can stream at a time so maybe the devices have a priority or one lends the connection to another.
I have a phone and I want to connect:
- a smartwatch
- bluetooth headphones
- a heart monitor
- one or more speakers as above
I might want to lend a device to someone in my household (e.g. the headphones or heart monitor)
To my mind this suggests we want a peer to peer network like we have with WIFI or ethernet. So why hasn't bluetooth evolved in this direction? It seems it have if I google "bluetooth piconet"
It looks like the second scenario ought to be supported (the phone as master and the rest as slaves) but I commonly find in android at least that pairing one device causes others to be disconnected. Is this because the slave needs to be a master temporarily to configure it?
How much of this is a 'mere' software issue and how much is down to issues with the protocol and technology itself?
I think the answer is that its down to the software. Any device wanting to act as the 'master' needs to support creating a piconet which is more advanced than you find in the average smartphone software. But this begs the question (as old as the invention of software) why isn't there better software?
I think I've mostly answered my own question here but perhaps someone out there can offer further enlightenment.
Related:
- Make two bluetooth modules communicate directly?
- Bluetooth Concurrent connection
- Pairing to a module containing multiple Bluetooth units
- https://electronics.stackexchange.com/a/430258/270158
- https://stackoverflow.com/questions/5005253/establishing-a-bluetooth-piconet-in-android
See also
