My Multisim Oscilloscope is ALWAYS doubling my input voltage.
If I put a 5Vp in from the function generator, it will show a sine wave with a 10Vp in the scope.
This is extremely frustrating and I would appreciate any help. Here is a screenshot:
This is the scope showing 5V/div - you can see it reaching two division, i.e. 10Vp
Figure 1: This is the scope showing 5V/div - you can see it reaching two division, i.e. 10Vp
    \$\begingroup\$ Try connecting to COM of signal generator instead of - \$\endgroup\$ – Simon Sultana Dec 4 '20 at 2:39
  • \$\begingroup\$ Does Multisim model the output impedance of the signal generator and input impedance of the oscilloscope? \$\endgroup\$ – Sredni Vashtar Dec 4 '20 at 3:47
8
Connection to function generator should be to COM (common/ground) instead of negative. Also add a ground point for good practice. Try that.
'-' connection is used for phase inversion
  • \$\begingroup\$ Many thanks, that solved it! \$\endgroup\$ – Adrian Salt Dec 4 '20 at 15:45
