Can I ask for help in identifying the following SMD component? Package is SOT-25. Marking is bPCGD . Probably is voltage detector but I dont know his parameters. It is a component of mainboard IP camera YI YHS3017. I add photos of the mainboard and a diagram of this component that I was able to measure. Pinuot 3 is connected to a nearby coil, pinout 2 is ground, pinout 5 is voltage from power supply (5V). I`ve looked in many catalogs but it is probably a unique label of the manufacturer. I suspected it might be the BD5242G but it doesn't match the ground pinouts.
Thanks for your help
enter image description here enter image description here enter image description here enter image description here
  • \$\begingroup\$ Thanks for Your answer. RT9193 has VIN ( Voltage input)to pinouts 1 - in my component VIN (+5V) is connect to pinout 4 ( in the drawn by me pinout 5). Probably VOUT in my component is pinout 1.Ground both is in pinout 2. I wonder what is mean small letter "b" on the marking? Its mean country of production? Or manufacturer designation? \$\endgroup\$
    – r adcza
    Commented Dec 7, 2020 at 13:51
I have looked around, and found also your forum post on a elektroda.pl. But looking further on this website with code bP and looking through the few ones with package SOT25/SOT3353 I think the correct component is RT9193. Especially because there is a coil connected to pin 4 or pin 5, my first guess was that it is some kind of voltage regulator.
Datasheet
