I am willing to include the channel matrix in my analytical model (which only includes pathloss and antenna gains). But from what I have seen, channel matrix can't be used to produce numerical results in an analytical model because it relies and should be based on real device tests.
Is my way of thinking wrong in this problem?
  • \$\begingroup\$ I don't understand the question – the thing is called channel matrix. It describes the channel, not just your device. \$\endgroup\$ Dec 7, 2020 at 17:32
  • \$\begingroup\$ @MarcusMüller yes, I want to model this channel in order to produce analytical results, specifically, I want to calculate the capacity when using MIMO \$\endgroup\$
    – medukrin
    Dec 7, 2020 at 17:38
  • \$\begingroup\$ well, then model it? The MIMO channel isn't any different than any other random channel there. \$\endgroup\$ Dec 8, 2020 at 9:03
  • \$\begingroup\$ @MarcusMüller Thank you for the answer, but my problem is how to get a channel matrix in order to produce numerical results \$\endgroup\$
    – medukrin
    Dec 9, 2020 at 17:07
