I am interested in a LiFePO4 Lithium Iron Phosphate battery product and wonder if anyone knows what type of terminal connector the battery has. Thanks in advance!
    \$\begingroup\$ Perhaps some variation of Anderson Powerpole, but generally you do not want to buy things which do not have meaningful specifications; a reputable supplier would tell you what the connector is. \$\endgroup\$ Dec 7, 2020 at 18:02
Anderson Powerpole
Powerpole connectors are available with current ratings up to 180 amperes. The size most commonly used is the 15/30/45 ampere-rated variety. These sizes all use the same plastic housing in multiple colors, differing only in the metal contact inserted into the housing (selected based on the ampacity and wire size). The colors can be used to signify signal types (power, speaker, logic, microphone audio, etc.) or differing voltages. Powerpole connectors can be attached side to side and also stacked on top of each other to make, for example, four connections with one plug insertion.
