I'm into DIY module-making for modular synthesizers. I came across this stripboard layout from the musician Look Mum No Computer for a module that will take an input signal (usually ±5V range of any shape via the "CV IN" jack), pass it through an ADC, and return high/low outputs corresponding to bit value, which can be used for various applications in modular synthesis.
I've made the circuit and it operates great. Just one problem, when the input signal drops into negative voltage, the ADC does not generate any outputs, which is an inconvenience as the module only works half the time, in essence.
My idea for fixing this issue was to add a bridge rectifier to the input signal coming in from the "CV IN" jack, thus ensuring that the input signal always stays positive. Although I am unsure exactly how I would go about adding this. The circuits for bridge rectifiers that I have looked at in the past require a positive/negative input and generate a positive/negative output, and "grounding" these negatives to each other negates the effect of the bridge rectifier. The jacks are also mounted to a metal plate, which is grounded to the GND line. For clarification, the bridge rectifier would be added between the "CV IN" jack and the green wire.
So my question is, can you add a bridge rectifier to this circuit and if so, how exactly? Or is there another way to essentially take the absolute value of the input signal coming in via the "CV IN" jack?
If clarification is needed, please ask, will be happy to provide more info.
