I am practicing on moore and mealy machine sequence detectors and I want to make sure if the mealy 011 sequence detector is correct.
  • \$\begingroup\$ No, it's not. You have two transitions from the first state labeled the same. \$\endgroup\$
    – Eugene Sh.
    Commented Dec 8, 2020 at 19:30
  • \$\begingroup\$ Never mind I figured it out, for the first transition it should be 0/0 and for the last state when I get 1 it should go to the initial state. Thank you \$\endgroup\$
    – P_M
    Commented Dec 8, 2020 at 19:44
Mealy and Moore State Diagrams to detect serial bit sequence 011.
Mealy & Moore State Diagrams
