I am kind of beginner about electronics and I want to understand how can I compare two different model of the same kind (lithium-ion) batteries?
I would like to understand this because I sent my robot vacuum to warranty and they exchanged the original battery (Hu Nan Giantsun power, 18650 4S1P (4INR19/66)) with another brand (in fact white label pack of 4x 18650BD) and I want to be sure they are compatible because of fire safety etc. and I would like to learn how to compare batteries.
Here is my original battery
And they changed it with NCR18650BD pack (white label but these codes can be seen under white plastic cover). It seems they manufactured by Panasonic but there is Panasonic label on them, is that possible or are they fake/non-Panasonic?) They look like this;
First difference is, new batteries are 3200 mAh batteries, what can it change? Duration of power? And the specs I've found on internet shows these data but I need help to correctly interpret and compare.
And it seems both of the battery packs has some small circuit under/top of them. What it does? Does it have any affect on charging/protection or just simple connection circuit?
And how can I be sure about the safety of using these new batteries?
