I have a 9 X 8 memory with me, there are 9 memory addresses with a byte of data in each.
I need to transfer the contents of this memory to a sub module but I'm one cycle.
    module top (input rst,
    input clk)
    reg [7:0]mem1[0:8];
    wire data_out;
    smallmem sm
     (.clk(clk),
      .data_in(data_out));
    endmodule
    module smallmem (input
     clk,input [7:0]
      data_in )
     reg [7:O] mem2 [0:9];
     endmodule
I need to transfer the whole data of mem1 of my top module to mem2 of my submodule smallmem.
Also, can the memory be written this way?
Consider the following snippet
module(input clk, input rst);
reg [7:0] buff [0:8];
reg [215:0] mem [0:254];
// Assuming I have a memory 'mem' with the dimensions as stated above
// and assuming the value of reg addR at the current posedge of clk is
//0.
always@(posedge clk)
begin
for(n=0;n<9;n=n+1)
   begin
    mem[(addR+0)][215-(24*n):208-(24*n)] <= buff[n][7:0];
    mem[(addR+1)][215-(24*n):208-(24*n)] <= buff[n][7:0];
    mem[(addR+2)][215-(24*n):208-(24*n)] <= buff[n][7:0];
   end
end
Assuming the value of addR is 0. If I run this design for one clock pulse will all the contents of memory 'buff' be written in the first three address of my memory 'mem'? I want content of addresses 0,3,6 of 'buff' to go in 1st,4th,7th,10th,13th,..,25th byte from MSB of 'mem'. Content of address 1,4,7 of 'buff' to go in 2nd, 5th, 8th, .. ,26th byte from MSB of 'mem' and Content of address 2,5,7 of 'buff' to go in 3rd, 6th, 9th, ... , 27th byte from MSB of 'mem'.
    \$\begingroup\$ What you are asking is borderline not possible with a "memory" and probably indicates you need to re-think the design overall. Many FPGA memory resources are implicitly dual port which may give you a solution. Another possibility would be propagating all of the writes which get the data into the original memory, into another as well. But ultimately good designs tend to be architectures that don't need this kind of behavior. Also asking for code to be created for your particular situation is really not what stack exchange sites are about. \$\endgroup\$ – Chris Stratton Dec 11 '20 at 16:20
  • \$\begingroup\$ Why do you want to do this? \$\endgroup\$ – Bruce Abbott Dec 11 '20 at 18:53
