I want to use Neopixels in a project which lights up some Neopixels, does a lot of computation and then changes some other Neopixels. Now since the program is synchronous I do not want to lose the present lit Neopixels.
I want to know whether the Neopixels remember their state or do we need to provide continuous pulses to control the Neopixels?
Thanks in advance!
The neopixel's core functionality is exactly that: being loaded with a value (or three for RGB), and then holding that.
But: these are designed as shift registers, so that you can have many in a string. So to change the state of an LED down the string, you need to overwrite all the values of the pixels coming before that pixel in the string.
  • \$\begingroup\$ The 'shift registers' concept came to my mind. I just wanted to be sure :-) \$\endgroup\$ – InputBlackBoxOutput Dec 12 '20 at 11:52
If you means what strings with WS2811, 2812, 2813 and similar, answer yes. They keep setting until it is rewriting or power down. After power up it "0"s, no light.
