I was about to attach an antenna to my 4g modem and thus trying to identify which connector is there on my modem board and i found this connector (4 of them, 2 for 4g and 2 for wifi).
1 2 3
I tried connecting u.fl female pigtail to it and it does not work. I suspect it is a female ipex, but i know you guys know better. Pls tell me.
Pls make use of the miniSIM card nearby for size reference, thank you.
It's a coax receptacle with an internal N/C switch.
The N/C switch brings a 50Ohm connection between the onboard/default (e.g. PCB trace type) antenna and the RF transceiver (Bluetooth, Wi-Fi, 2G/3G/4G or whatever). When an external antenna is plugged into the receptacle, the default antenna gets disconnected from the transceiver. It also enables a connection to measurement equipment (e.g. spectrum analyzer) to measure the transmit/receive power.
Murata's SWF series and Hirose's MS-156C series are quite popular.
  • \$\begingroup\$ wow thank you very much, this realy clearly solved my question. \$\endgroup\$ – yuda Feb 16 at 12:47
  • \$\begingroup\$ @yuda then you can accept my answer by clicking the tick button so that the question does not remain open. \$\endgroup\$ – Rohat Kılıç Feb 16 at 13:01
