I have been scratching my head with this one for a while. Probably a simple problem to people familiar with VHDL on Vivado.
I have inserted all my code below. I am creating a 32 bit register from D type FF's with an enabler block to load its stored value out. Basically this circuit where set is the clock in VHDL:
I have tested the register and am happy with its functionality. The enabler was added into the project and now I am getting an error when synthesising. Below is an image of my error message:
It is saying my top_level file and the top_level_tb file have difference somewere but I cannot find my mistake. I think it is something to do with the component instantiations.
Thanks for anyone taking the time to help!
Data_Bus_Size_Package
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
package Architecture_size is
constant Data_width : integer := 32;
subtype Data_Size is std_logic_vector(Data_width-1 downto 0);
end package Architecture_size;
Top_Level
library IEEE;
use work.Architecture_size.ALL;
entity Top_Level is
Port ( Data_in : in std_logic_vector(Data_width-1 downto 0);
Reset_in : in std_logic;
Clock_in : in std_logic;
Enable_in : in std_logic;
Data_out : out std_logic_vector(Data_width-1 downto 0)
end Top_Level;
architecture Layout of Top_Level is
component D_Type_FF_Register is
Port ( D : in std_logic_vector(Data_width-1 downto 0);
Clock : in std_logic;
Reset : in std_logic;
Q : out std_logic_vector(Data_width-1 downto 0)
end component;
component Enabler_Block is
Port ( A : in std_logic_vector(Data_width-1 downto 0);
Enable : in std_logic;
end component;
signal temp_wires_0 : std_logic_vector(Data_width-1 downto 0);
begin
Register_instance : D_Type_FF_Register port map (D => Data_in , Q => temp_wires_0 , Clock => Clock_in, Reset => Reset_in);
Enabler_instance : Enabler_Block port map (A => temp_wires_0 , Q => Data_out , Enable => Enable_in);
end Layout;
Top_Level_TB
library IEEE;
entity Top_Level_TB is
end Top_Level_TB;
architecture simulation of Top_Level_TB is
component Top_Level is
Data_out : out std_logic_vector(Data_width-1 downto 0));
end component;
signal Data_in_TB : std_logic_vector(Data_width-1 downto 0) := "00000000000000000000000000000000";
signal Clock_in_TB : std_logic := '0';
signal Reset_in_TB : std_logic := '0';
signal Enable_in_TB : std_logic := '0';
signal Data_out_TB : std_logic_vector(Data_width-1 downto 0);
constant clock_period : time := 10 ns;
begin
uut: Top_Level port map (
Data_in => Data_in_TB,
Clock_in => Clock_in_TB,
Reset_in => Reset_in_TB,
Enable_in => Enable_in_TB,
Data_out => Data_out_TB);
clock_process :process
begin
Clock_in_TB <= '0';
wait for clock_period/2;
Clock_in_TB <= '1';
end process;
stim_proc: process
begin
wait for 100 ns;
wait for clock_period*10;
Reset_in_TB <= '0';
Enable_in_TB <= '0';
Data_out_TB <= "00000000000000000000000000000000";
wait for clock_period*2;
Reset_in_TB <= '0';
Data_out_TB <= "11111111111111111111111111111111";
Reset_in_TB <= '0';
Reset_in_TB <= '0';
Reset_in_TB <= '0';
Enable_in_TB <= '1';
Reset_in_TB <= '0';
end process;
end;
D_Type_FF_Register
library IEEE;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity D_Type_FF_Register is
Q : out std_logic_vector(Data_width-1 downto 0));
end D_Type_FF_Register;
architecture Behavioral of D_Type_FF_Register is
component D_Type_FF is
Port ( D : in std_logic;
Q : out std_logic);
end component;
begin
bits: for i in 0 to Data_width-1 generate
instance: D_Type_FF port map (D => D(i), Q => Q(i), Clock => Clock, Reset => Reset );
end generate;
end Behavioral;
D_Type_FF
library IEEE;
entity D_Type_FF is
Q : out std_logic);
end D_Type_FF;
architecture Behavioral of D_Type_FF is
begin
process (Clock, Reset)
begin
if (Clock'event and Clock='1') then
if Reset = '1' then Q <= '0';
else Q <= D;
end if;
end if;
end process;
end Behavioral;
Enabler_Block
library IEEE;
entity Enabler_Block is
end Enabler_Block;
architecture Behavioral of Enabler_Block is
component One_Bit_Enabler is
Port ( A : in std_logic;
Q : out std_logic);
end component;
begin
instance: One_Bit_Enabler port map (A => A(i), Q => Q(i), Enable => Enable);
end generate;
end Behavioral;
One_Bit_Enabler
library IEEE;
entity One_Bit_Enabler is
Q : out std_logic);
end One_Bit_Enabler;
architecture Behavioral of One_Bit_Enabler is
begin
Q <= A and Enable;
end Behavioral;
