The input frequency is 2 MHz and the output should be 2 kHz since I used mode 3 and the initial count value N=1000d.
The output frequency is 500kHz.
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityThe input frequency is 2 MHz and the output should be 2 kHz since I used mode 3 and the initial count value N=1000d.
You are using the BCD mode and loading in a divider that is illegal BCD number.
