I am tying to implement something using PIR sensor and Arduino UNO. I did the wiring like this
VCC - 5v
GND - GND
Dout - Pin 3
Here is my code
int calibrationTime = 30; //the time when the sensor outputs a low impulse
long unsigned int lowIn; //the amount of milliseconds the sensor has to be low //before we assume all motion has stopped
long unsigned int pause = 5000;
boolean lockLow = true;
boolean takeLowTime;
int pirPin = 3; //the digital pin connected to the PIR sensor's output
int ledPin = 13; /////////////////////////////
//SETUP
void setup() {
Serial.begin(9600);
pinMode(pirPin, INPUT);
pinMode(ledPin, OUTPUT);
digitalWrite(pirPin, LOW); //give the sensor some time to calibrate
Serial.print("calibrating sensor ");
for (int i = 0; i < calibrationTime; i++)
Serial.print("."); delay(1000);
Serial.println(" done");
Serial.println("SENSOR ACTIVE");
delay(50);
//LOOP
void loop() {
if (digitalRead(pirPin) == HIGH)
Serial.println("Detected motion");
digitalWrite(ledPin, HIGH); //the led visualizes the sensors output pin state
if (lockLow) { //makes sure we wait for a transition to LOW before any further output is made:
lockLow = false;
Serial.println("---");
Serial.print("motion detected at ");
Serial.print(millis() / 1000);
Serial.println(" sec");
delay(50);
takeLowTime = true;
if (digitalRead(pirPin) == LOW)
{ digitalWrite(ledPin, LOW); //the led visualizes the sensors output pin state
if (takeLowTime)
{ lowIn = millis(); //save the time of the transition from high to LOW
takeLowTime = false; //make sure this is only done at the start of a LOW phase
} //if the sensor is low for more than the given pause, //we assume that no more motion is going to happen
if (!lockLow && millis() - lowIn > pause)
//makes sure this block of code is only executed again after //a new motion sequence has been detected
lockLow = true;
Serial.print("motion ended at "); //output
Serial.print((millis() - pause) / 1000);
delay(50);
But after calibration its not at all showing its detects some motion when there are many. I tried more sensitivity by turning the right potentiometer all towards right (Clockwise). Still nothing detected.
Then I tried removing the White cover of sensor and it detected some motion only when I touched the sensor.
I tried with another sensor, it works the same. It detect some movement only when I touched it.
void loop() { digitalWrite(ledPin, digitalRead(pirPin)); }
