okay guys forgive me I'm just a dumb electrician/carpenter with a dream. I have caught the bug real bad in regards to home distillin. specifically still building. here is the deal, I didn't think in a million years the heating element in my kettle was over 12 amps but surprise its 16 something. i bought a ready made pid controller thinking i could plug and play until i noticed it was a 2000 watt element. So now i have to step down the voltage so i dont fry the inkbird. later i will build an inkbird 100vh with 25A ssr but for now i have got to do a flow test of my flagship still. can i just get a halogen dimmer to get me through the test? i was going to put the 20A dimmer switch in line with an amp meter and regulate it down to below 15A a little. i want to build a small still around the inkbird ITC-608t and dont want to hurt it. What say you engineers? will it work? there is a jar of awesome in it for anyone who helps!
  • \$\begingroup\$ Dimmer switches don't actually reduce the current. They switch it on and off rapidly. That's good enough to dim lamps or reduce the heat from a heater, but may not help your controller. \$\endgroup\$ – Simon B Dec 14 '20 at 8:46
  • \$\begingroup\$ so is a dimmer a PWM? are there different types of dimmers? or a dimmer that is special some how? should i just put together a bunch of resistors in series? \$\endgroup\$ – Christopher Larsen Dec 15 '20 at 10:57
  • \$\begingroup\$ AC dimmers aren't usually PWM. Instead, they chop a portion out of each half-cycle of the AC sinewave. Leading edge dimmers chop off the start of the waveform, trailing edge dimmers chop off the end. \$\endgroup\$ – Simon B Dec 15 '20 at 11:25
