I have an FPGA project on Vivado in VHDL that contains lots of components, let's call them 'blocks'. I am testing these 'blocks' individually before integrating them together for the final design.
Anyway I am creating a separate source file for each block, where each block contains sometimes 3 or 4 components with signals connecting between them. I then write a suitable testbench source file to test the block. Now as the signals between components isn't in the entity port map of the file, I can't map them into my testbench file to view the signals on simulation.
My question is: Is there a way to view signals declared in my main source file in my testbench simulation file?
EDIT
Hopefully this will shed more information to my problem. I have pasted my project hierarchy, files and images. This is a 4 bit register with an enabler. I know the design works perfect as the register stores and enables the output fine, I would just like to see the stored register value in simulation as it is stored on signal wires passing between the register and enabler components. I think you only need to see the topo_level files as it contains the signals!
Simulation Image
Simulation Image
Project hierarchy
Project Overview Image
Top_Level file
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use work.Architecture_size.ALL;
entity Top_Level is
 Port ( Data_in : in std_logic_vector(Data_width-1 downto 0);
        Reset_in : in std_logic;
        Clock_in : in std_logic;
        Enable_in : in std_logic;
        Data_out : out std_logic_vector(Data_width-1 downto 0)
end Top_Level;
architecture Layout of Top_Level is
component D_Type_FF_Register is
 Port ( D : in std_logic_vector(Data_width-1 downto 0);
        Clock : in std_logic;
        Reset : in std_logic;
        Q : out std_logic_vector(Data_width-1 downto 0)
end component;
component Enabler_Block is
 Port ( A : in std_logic_vector(Data_width-1 downto 0);
        Enable : in std_logic;
end component;
signal temp_wires : std_logic_vector(Data_width-1 downto 0);
begin
Register_instance : D_Type_FF_Register port map (D => Data_in , Q => temp_wires , Clock => Clock_in, Reset => Reset_in);
Enabler_instance : Enabler_Block port map (A => temp_wires , Q => Data_out , Enable => Enable_in);
end Layout;
**Top_Level_TB file
library IEEE;
entity Top_Level_TB is
end Top_Level_TB;
architecture simulation of Top_Level_TB is
component Top_Level is
        Data_out : out std_logic_vector(Data_width-1 downto 0));
 end component;
   signal Data_in_TB  : std_logic_vector(Data_width-1 downto 0) := (others => '0');
   signal Clock_in_TB : std_logic := '0';
   signal Reset_in_TB : std_logic := '0';
   signal Enable_in_TB : std_logic := '0';
   signal Data_out_TB : std_logic_vector(Data_width-1 downto 0);
   signal temp_wires_TB : std_logic_vector(Data_width-1 downto 0) := (others => '0');
   constant clock_period : time := 10 ns;
begin
   uut: Top_Level port map (
          Data_in => Data_in_TB,
          Clock_in => Clock_in_TB,
          Reset_in => Reset_in_TB,
          Enable_in => Enable_in_TB,
          Data_out => Data_out_TB);
   clock_process :process
   begin
        Clock_in_TB <= '0';
        wait for clock_period/2;
        Clock_in_TB <= '1';
   end process;
   stim_proc: process
   begin
     wait for 100 ns;
     wait for clock_period*10;
     Reset_in_TB <= '0';
     Enable_in_TB <= '0';
     Data_in_TB <= (others => '0');
     wait for clock_period*2;
     Reset_in_TB <= '0';
     Data_in_TB <= (others => '1');
     Reset_in_TB <= '0';
     Reset_in_TB <= '0';
     Reset_in_TB <= '0';
     Enable_in_TB <= '1';
     Reset_in_TB <= '0';
   end process;
end;
  • \$\begingroup\$ In simulation settings tick the log all signals, then run the simulation, now if u click the module in hierarchy u will see the signals toggling when u add them to waveform viewer \$\endgroup\$ Commented Dec 14, 2020 at 13:48
  • \$\begingroup\$ Will give this a try, thanks \$\endgroup\$
    – David777
    Commented Dec 14, 2020 at 14:16
    \$\begingroup\$ @David777, you are showing signal temp_wires_TB : std_logic_vector(Data_width-1 downto 0) := (others => '0'); of entity Top_Level_TB in your simulation whereas you have signal temp_wires : std_logic_vector(Data_width-1 downto 0); in your Top_Level entity. I think that is the difference. \$\endgroup\$
    – tim
    Commented Dec 15, 2020 at 15:56
    \$\begingroup\$ @David777, I haven't used the Xilinx Vivado tool chain for a while, but you should be able to expand the design hierarchy in the simulator and pick the signals you want to show, i.e. temp_wires. The equivalent in Modelsim is to expand the hierarchy or find the signal/variable/constant in the source file window, right-click on it and choose "Add Wave". There should be something similar in Vivado. \$\endgroup\$
    – tim
    Commented Dec 15, 2020 at 16:54
    \$\begingroup\$ @David777, does this help? \$\endgroup\$
    – tim
    Commented Dec 15, 2020 at 17:20
You are showing signal temp_wires_TB : std_logic_vector(Data_width-1 downto 0) := (others => '0'); of entity Top_Level_TB in your simulation whereas you have signal temp_wires : std_logic_vector(Data_width-1 downto 0); in your Top_Level entity. I think that is the difference.
I haven't used the Xilinx Vivado tool chain for a while, but you should be able to expand the design hierarchy in the simulator and pick the signals you want to show, i.e. temp_wires, something like this: How to add new signals for waveform simulation
The equivalent in Modelsim is to expand the hierarchy or find the signal/variable/constant in the source file window, right-click on it and choose "Add Wave". There should be something similar in Xilinx Vivado.
