9
Here are a handful of capacitors, that I just salvaged from a burned out a 230VAC to 12VAC power supply. O those, I am familiar only with the electrolytics and how to read their capacitance, maximum voltage, polarity and maximum opperationg temperature.
What are the other cap types shown into the picture and how to read their parameters? Optionally, in what applications is each of those types preferable? enter image description here enter image description here enter image description here
  • 8
    \$\begingroup\$ I guess the blue components are not capacitors but varistors (en.wikipedia.org/wiki/Varistor). \$\endgroup\$
    – Curd
    Jan 11, 2013 at 10:34
    \$\begingroup\$ The yellow ones are MPX Metallized Polypropylene capacitor \$\endgroup\$
    – jippie
    Jan 11, 2013 at 10:36
    \$\begingroup\$ X2 indicates a safety classification: justradios.com/X2capacitors.html \$\endgroup\$
    – jippie
    Jan 11, 2013 at 10:37
    \$\begingroup\$ Jippie is right about the X2 caps. 0.47 uf 250V AC and 0.068 uf (68nf) 275V. Probably used on the AC mains side of the PSU. The blue ones are varistors. They start to conduct at some voltage, probably about 15V, to remove high voltage spikes. The orange ones are probably marked on the other side? Oh, I can just see a marking on the top, but not enough to read. I expect values like the yellow ones, but only suitable for lower voltages (100V or less) \$\endgroup\$
    – user16324
    Jan 11, 2013 at 10:49
  • \$\begingroup\$ Oh, the orange ones read something in the lines of 100nJ400. \$\endgroup\$
    – Vorac
    Jan 11, 2013 at 14:20
Yellow and Red: Film capacitors. Red: Without safety approval. Yellow: With safety approval. (Colors: Just in your case. It's not because of the colors, it's because of the X... markings! Any type may be made in any color!) Depending on the conductor (real film or metallic layer) and dielectric, they feature (very) low ESR and (very) low dissipation factor. Good for switching power applications whenever you need more capacitance than ceramic capacitors can offer. You added the info that the red ones read 100nJ400, which means 100 nF; Tolerance: 5 %; 400 V. Common tolerance codes for capacitors: J = ± 5%; K = ± 10%; M = ± 20%.
Blue, from left to right: 2 x Safety-Rated Ceramic Disc Capacitors. Very low ESR, sometimes with a big tolerance and temperature coefficient, though. The third blue disc from the left appears to be a varistor, not a capacitor. It is labeled 7K471. 7K means it has a disk size of 7 mm (the disk size corresponds to the energy it can absorb) and it starts to conduct at or above "471" = 47*101 V = 470 V. Number four is 221; 1KV (no safety rating visible), meaning 22 * 101 pF = 220 pF; max. voltage 1 kV.
Black: Electrolytic Capacitors. Some bad properties, but you get an awesome C*V product per volume.
Hints on reading the values:
https://electronics.stackexchange.com/a/33454/930
Identifying Capacitors
Hints on the safety ratings: X means you may use these between live and neutral (L and N). This is a critical application because a small leakage path will continuously be fed from the lines and fires may result. I have had one of these fail in a HP function generator last year and the room smelled toxic for weeks, even though I washed out all the stuff left by the smoldering decomposition of the cap - and luckily the design of the cap was of the self-extinguishing type. Y means you may use the caps between L or N and PE. Critical because fires may result for the reason just explained, and because an insulation failure may result in L being connected to the housing (PE). The number behind the X or Y shows the class (good or better). Datasheets will tell you more. Search for X1, X2, Y1 or Y2 and EMI capacitor. EMI because these capacitors are usually used in input filters, often before the fuse, and thus exposed directly the the mains terminals feeding your device.
    \$\begingroup\$ Good eye on the blue ones I thought were varistors. I couldn't see anything that looked like a value. But looking again, the top row ZZZ could be 222 on a dot matrix printer. Then it is 222 Y2 250 or 2.2 nf, 250V, Y2 safety rating. Not sure about nos 3,4 though. No.3 could be 470pf (471) or they could be varistors. But if No.4 really says 1KV it's a low value 1000V capacitor. \$\endgroup\$
    – user16324
    Jan 11, 2013 at 13:22
    \$\begingroup\$ Blue numbers 1 and 2 are most likely 2.2nF Y-caps. Blue number three appears to be a MOV. Blue number four appears to say 221 on the top row, which implies 220pF. \$\endgroup\$ Jan 11, 2013 at 13:59
