What is the fastest (in clock cycles) division algorithm that will run on an ATMEGA1284?
  • The dividend is an unsigned 16-bit number passed into the algorithm in a pair of 8-bit registers.
  • The divisor is an unsigned 16-bit number passed into the algorithm in a pair of 8-bit registers.
  • The quotient and remainder are passed out in any pairs of 8-bit registers.
  • The algorithm code (plus any lookup tables) must consume less than 5K bytes of flash memory.
  • The algorithm may return any values for division by 0.
AVR Instruction Set Manual:
https://ww1.microchip.com/downloads/en/devicedoc/atmel-0856-avr-instruction-set-manual.pdf
AVR200: Multiply and Divide Routines:
https://ww1.microchip.com/downloads/en/AppNotes/doc0936.pdf
The algorithm I have so far takes between 57 and 68 clock cycles and uses 768 bytes of lookup tables. I ran an exhaustive 16-hour test that verified that it calculates the correct quotient and remainder for all 2^32 combinations of dividend and divisor.
;ARGUMENTS:  r16, r17, r18, r19
;  r16:r17 = N (numerator)
;  r18:r19 = D (divisor)
;RETURNS:    r20, r21
;  r20:r21 (quotient)
;  r22:r23 (remainder)
;DESCRIPTION:  divides an unsigned 16 bit number N by unsigned 16 bit divisor D
;ALGORITHM OVERVIEW
;RZERO = 0;
;if(D < 256){
;  N2 = (N * ((R1H_TBL[D] << 8) + R1L_TBL[D])) >> 16;
;  P  = N2 * D
;}else{
;  D1 = (R1H_TBL[D] * D) >> 8
;  N1 = (R1H_TBL[D] * N) >> 8
;  if(D1 < 256){
;    N2 = N1 >> 8;
;  }else{
;    N2 = N2 * R2_TBL[D1 & 0xFF];
;  P = N2 * D;
;  if(P > 65535){
;    N2 = N2 - 1    ;//Decrement quotient
;    N1 = N2 - P + D;//Calculate remainder
;    return;//return quotient in N2, remainder in N1
;N1 = N - P;
;if(P > N){
;  N2 = N2 - 1;//decrease quotient
;  N1 = N1 + D;//increase reamainder
;if(N1 > D){
;  N2 = N2 + 1;
;  N1 = N1 - D;
.align 256
;Recipricol table #1, high byte.
;R1H_TBL[x] = min( high(2^16/x) / 256 , 255)
R1H_TBL:
.db 0xFF, 0xFF, 0x80, 0x55, 0x40, 0x33, 0x2A, 0x24, 0x20, 0x1C, 0x19, 0x17, 0x15, 0x13, 0x12, 0x11
.db 0x10, 0x0F, 0x0E, 0x0D, 0x0C, 0x0C, 0x0B, 0x0B, 0x0A, 0x0A, 0x09, 0x09, 0x09, 0x08, 0x08, 0x08
.db 0x08, 0x07, 0x07, 0x07, 0x07, 0x06, 0x06, 0x06, 0x06, 0x06, 0x06, 0x05, 0x05, 0x05, 0x05, 0x05
.db 0x05, 0x05, 0x05, 0x05, 0x04, 0x04, 0x04, 0x04, 0x04, 0x04, 0x04, 0x04, 0x04, 0x04, 0x04, 0x04
.db 0x04, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03
.db 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x02, 0x02, 0x02, 0x02, 0x02, 0x02, 0x02, 0x02, 0x02, 0x02
.db 0x02, 0x02, 0x02, 0x02, 0x02, 0x02, 0x02, 0x02, 0x02, 0x02, 0x02, 0x02, 0x02, 0x02, 0x02, 0x02
.db 0x02, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01
.db 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01
;Recipricol table #1, low byte.
;R1L_TBL[x] = min( low(2^16/x) mod 256 , 255)
R1L_TBL:
.db 0xFF, 0xFF, 0x00, 0x55, 0x00, 0x33, 0xAA, 0x92, 0x00, 0x71, 0x99, 0x45, 0x55, 0xB1, 0x49, 0x11
.db 0x00, 0x0F, 0x38, 0x79, 0xCC, 0x30, 0xA2, 0x21, 0xAA, 0x3D, 0xD8, 0x7B, 0x24, 0xD3, 0x88, 0x42
.db 0x00, 0xC1, 0x87, 0x50, 0x1C, 0xEB, 0xBC, 0x90, 0x66, 0x3E, 0x18, 0xF4, 0xD1, 0xB0, 0x90, 0x72
.db 0x55, 0x39, 0x1E, 0x05, 0xEC, 0xD4, 0xBD, 0xA7, 0x92, 0x7D, 0x69, 0x56, 0x44, 0x32, 0x21, 0x10
.db 0x00, 0xF0, 0xE0, 0xD2, 0xC3, 0xB5, 0xA8, 0x9B, 0x8E, 0x81, 0x75, 0x69, 0x5E, 0x53, 0x48, 0x3D
.db 0x33, 0x29, 0x1F, 0x15, 0x0C, 0x03, 0xFA, 0xF1, 0xE8, 0xE0, 0xD8, 0xD0, 0xC8, 0xC0, 0xB9, 0xB1
.db 0xAA, 0xA3, 0x9C, 0x95, 0x8F, 0x88, 0x82, 0x7C, 0x76, 0x70, 0x6A, 0x64, 0x5E, 0x59, 0x53, 0x4E
.db 0x49, 0x43, 0x3E, 0x39, 0x34, 0x30, 0x2B, 0x26, 0x22, 0x1D, 0x19, 0x14, 0x10, 0x0C, 0x08, 0x04
.db 0x00, 0xFC, 0xF8, 0xF4, 0xF0, 0xEC, 0xE9, 0xE5, 0xE1, 0xDE, 0xDA, 0xD7, 0xD4, 0xD0, 0xCD, 0xCA
.db 0xC7, 0xC3, 0xC0, 0xBD, 0xBA, 0xB7, 0xB4, 0xB2, 0xAF, 0xAC, 0xA9, 0xA6, 0xA4, 0xA1, 0x9E, 0x9C
.db 0x99, 0x97, 0x94, 0x92, 0x8F, 0x8D, 0x8A, 0x88, 0x86, 0x83, 0x81, 0x7F, 0x7D, 0x7A, 0x78, 0x76
.db 0x74, 0x72, 0x70, 0x6E, 0x6C, 0x6A, 0x68, 0x66, 0x64, 0x62, 0x60, 0x5E, 0x5C, 0x5A, 0x58, 0x57
.db 0x55, 0x53, 0x51, 0x50, 0x4E, 0x4C, 0x4A, 0x49, 0x47, 0x46, 0x44, 0x42, 0x41, 0x3F, 0x3E, 0x3C
.db 0x3B, 0x39, 0x38, 0x36, 0x35, 0x33, 0x32, 0x30, 0x2F, 0x2E, 0x2C, 0x2B, 0x29, 0x28, 0x27, 0x25
.db 0x24, 0x23, 0x21, 0x20, 0x1F, 0x1E, 0x1C, 0x1B, 0x1A, 0x19, 0x18, 0x16, 0x15, 0x14, 0x13, 0x12
.db 0x11, 0x0F, 0x0E, 0x0D, 0x0C, 0x0B, 0x0A, 0x09, 0x08, 0x07, 0x06, 0x05, 0x04, 0x03, 0x02, 0x01
;Recipricol table #2
;R2_TBL[x] = min( 2^16/(x+256), 255)
R2_TBL:
.db 0xFF, 0xFF, 0xFE, 0xFD, 0xFC, 0xFB, 0xFA, 0xF9, 0xF8, 0xF7, 0xF6, 0xF5, 0xF4, 0xF3, 0xF2, 0xF1
.db 0xF0, 0xF0, 0xEF, 0xEE, 0xED, 0xEC, 0xEB, 0xEA, 0xEA, 0xE9, 0xE8, 0xE7, 0xE6, 0xE5, 0xE5, 0xE4
.db 0xE3, 0xE2, 0xE1, 0xE1, 0xE0, 0xDF, 0xDE, 0xDE, 0xDD, 0xDC, 0xDB, 0xDB, 0xDA, 0xD9, 0xD9, 0xD8
.db 0xD7, 0xD6, 0xD6, 0xD5, 0xD4, 0xD4, 0xD3, 0xD2, 0xD2, 0xD1, 0xD0, 0xD0, 0xCF, 0xCE, 0xCE, 0xCD
.db 0xCC, 0xCC, 0xCB, 0xCA, 0xCA, 0xC9, 0xC9, 0xC8, 0xC7, 0xC7, 0xC6, 0xC5, 0xC5, 0xC4, 0xC4, 0xC3
.db 0xC3, 0xC2, 0xC1, 0xC1, 0xC0, 0xC0, 0xBF, 0xBF, 0xBE, 0xBD, 0xBD, 0xBC, 0xBC, 0xBB, 0xBB, 0xBA
.db 0xBA, 0xB9, 0xB9, 0xB8, 0xB8, 0xB7, 0xB7, 0xB6, 0xB6, 0xB5, 0xB5, 0xB4, 0xB4, 0xB3, 0xB3, 0xB2
.db 0xB2, 0xB1, 0xB1, 0xB0, 0xB0, 0xAF, 0xAF, 0xAE, 0xAE, 0xAD, 0xAD, 0xAC, 0xAC, 0xAC, 0xAB, 0xAB
.db 0xAA, 0xAA, 0xA9, 0xA9, 0xA8, 0xA8, 0xA8, 0xA7, 0xA7, 0xA6, 0xA6, 0xA5, 0xA5, 0xA5, 0xA4, 0xA4
.db 0xA3, 0xA3, 0xA3, 0xA2, 0xA2, 0xA1, 0xA1, 0xA1, 0xA0, 0xA0, 0x9F, 0x9F, 0x9F, 0x9E, 0x9E, 0x9D
.db 0x9D, 0x9D, 0x9C, 0x9C, 0x9C, 0x9B, 0x9B, 0x9A, 0x9A, 0x9A, 0x99, 0x99, 0x99, 0x98, 0x98, 0x98
.db 0x97, 0x97, 0x97, 0x96, 0x96, 0x95, 0x95, 0x95, 0x94, 0x94, 0x94, 0x93, 0x93, 0x93, 0x92, 0x92
.db 0x92, 0x91, 0x91, 0x91, 0x90, 0x90, 0x90, 0x90, 0x8F, 0x8F, 0x8F, 0x8E, 0x8E, 0x8E, 0x8D, 0x8D
.db 0x8D, 0x8C, 0x8C, 0x8C, 0x8C, 0x8B, 0x8B, 0x8B, 0x8A, 0x8A, 0x8A, 0x89, 0x89, 0x89, 0x89, 0x88
.db 0x88, 0x88, 0x87, 0x87, 0x87, 0x87, 0x86, 0x86, 0x86, 0x86, 0x85, 0x85, 0x85, 0x84, 0x84, 0x84
.db 0x84, 0x83, 0x83, 0x83, 0x83, 0x82, 0x82, 0x82, 0x82, 0x81, 0x81, 0x81, 0x81, 0x80, 0x80, 0x80
.def NH    = r16 .def NL    = r17
.def DH    = r18 .def DL    = r19
.def N2H   = r20 .def N2L   = r21
.def N1H   = r22 .def N1L   = r23
.def PRODL = r0  .def PRODH = r1
.def PH    = r2  .def PL    = r3
.def D1H   = r4  .def D1L   = r5
.def RZERO = r6
.def Rx    = r7
idivu_16x16_x:
    clr RZERO                 ;1
    ;Check that DH is not zero
    tst DH                    ;1
    brne idivu_16x16_x_dhne   ;2
    ;code for D < 256
idivu_16x8:
    ;lookup low byte of recipricol into P.
    ;where P = min(2^16 / D,2^16-1)
    mov zl, DL               ;1
    ldi zh, high(R1L_TBL*2)  ;1
    lpm PL, Z                ;3
    ldi zh, high(R1H_TBL*2)  ;1
    lpm PH, Z                ;3
    ;calculate N2 = (P * N) >> 16
    ;     NH:NL
    ;  X  RH:RL
    ;   N2H    |   N2L    |  N1H     | dropped
    ;          |          | H(PL*NL) | L(PL*NL)
    ;          | H(PL*NH) | L(PL*NH) |
    ;          | H(PH*NL) | L(PH*NL) |
    ; H(PH*NH) | L(PH*NH) |          |
    mul NL , PL     ;1  PL*NL
    mov N1H, PRODH  ;1  N1H <= H(PL*NL)
    mul NH , PH     ;1  PH*NH
    mov N2H, PRODH  ;1  N2H <= H(PH*NH)
    mov N2L, PRODL  ;1  N2L <= L(PH*NH)
    mul NH , PL     ;1  PL*NH
    add N1H, PRODL  ;1  N1H <= H(PL*NL) + L(PL*NH)
    adc N2L, PRODH  ;1  N2L <= L(PH*NH) + H(PL*NH)
    adc N2H, RZERO  ;1  propagate carry to N2H
    mul NL , PH     ;1  PH*NL
    add N1H, PRODL  ;1  N1H <= H(PL*NL) + L(PL*NH) + L(PH*NL)
    adc N2L, PRODH  ;1  N2L <= H(PH*NL) + L(PH*NH) + H(PL*NH)
    ;calculate P = N2 * DL ,note DH=0
    mul N2L, DL              ;1
    mov PL, PRODL            ;1
    mov PH, PRODH            ;1
    mul N2H, DL              ;1
    add PH, PRODL            ;1
    rjmp idivu_16x16_x_adj_n ;2
    ;code for D >= 256
idivu_16x16_x_dhne:
    ;Lookup Rx = min(256 / DH, 255)
    mov zl, DH               ;1
    lpm Rx, Z                ;3
    ;D1 = (D * Rx) >> 8
    mul Rx , DH              ;1
    mov D1L, PRODL           ;1
    mov D1H, PRODH           ;1
    mul Rx , DL              ;1
    add D1L, PRODH           ;1
    adc D1H, RZERO           ;1
    ;N1 = (D * Rx) >> 8
    mul Rx , NH              ;1
    mov N1L, PRODL           ;1
    mov N1H, PRODH           ;1
    mul Rx , NL              ;1
    add N1L, PRODH           ;1
    adc N1H, RZERO           ;1
    ;if D1H = 0 then use Rx = 256, otherwise use table
    tst D1H                  ;1
    brne idivu_16x16_x_dxhne ;2
    mov N2L, N1H             ;1
    clr N2H                  ;1
    rjmp idivu_16x16_x_checkn;2
    idivu_16x16_x_dxhne:
    ;Lookup Rx = (2 ^ 16) \ (256 + D1H)
    mov zl, D1L              ;1
    ldi zh, high(R2_TBL*2)   ;1
    lpm Rx, Z                ;3
    ;N2 = (N1 * R2) >> 16
    mul Rx  , N1H            ;1
    mov PL  , PRODL          ;1
    mov N2L , PRODH          ;1
    mul Rx , N1L             ;1
    add PL , PRODH           ;1
    adc N2L, RZERO           ;1
    clr N2H                  ;1
    idivu_16x16_x_checkn:
    ;Check result (it may be off by +/- 1)
    ;P = N2 * D
    ;NOTE:  N2 <=255 so NxH = 0, also P < 2^16 so we can discard upper byte of DH * NxL
    mul DL , N2L             ;1
    mov PL, PRODL            ;1
    mov PH, PRODH            ;1
    mul DH , N2L             ;1
    add PH , PRODL           ;1
    brcc idivu_16x16_x_adj_n ;2
    ;if multiply overflowed then...
    ;decrement quotient
    ;calculate remainder as N - P + D
    subi N2L, 0x01           ;1
    sbci N2H, 0x00           ;1
    mov N1L, NL              ;1
    mov N1H, NH              ;1
    sub N1L, PL              ;1
    sbc N1H, PH              ;1
    add  N1L, DL             ;1
    adc  N1H, DH             ;1
    rjmp idivu_16x16_x_end   ;2
    ;Adjust result up or down by 1 if needed.
    idivu_16x16_x_adj_n:
    ;Add -P to N, with result in P
    mov N1L, NL              ;1
    mov N1H, NH              ;1
    sub N1L, PL              ;1
    sbc N1H, PH              ;1
    brsh idivu_16x16_x_pltn  ;2
    idivu_16x16_x_decn2:
    ;if P > N then decrement quotient, add to remainder
    subi N2L, 0x01           ;1
    sbci N2H, 0x00           ;1
    add  N1L, DL             ;1
    adc  N1H, DH             ;1
    idivu_16x16_x_pltn:
    ;test remainder to D
    cp  N1L, DL              ;1
    cpc N1H, DH              ;1
    ;if remainder < D then goto end
    brlo idivu_16x16_x_end   ;2
    ;if remainder >= D then increment quotient, reduce remainder
    subi N2L, 0xFF           ;1
    sbci N2H, 0xFF           ;1
    sub N1L, DL              ;1
    sbc N1H, DH              ;1
    idivu_16x16_x_end:
    ret
    .undef NH    .undef NL
    .undef DH    .undef DL
    .undef N2H   .undef N2L
    .undef N1H   .undef N1L
    .undef PRODL .undef PRODH
    .undef PH    .undef PL
    .undef D1H   .undef D1L
    .undef RZERO
    .undef Rx
    \$\begingroup\$ What is your question, exactly? No doubt there might be faster algorithms, but what exactly is your definition of the “fastest” algorithm? Are you asking us to optimize your code? \$\endgroup\$
    – StarCat
    Dec 14, 2020 at 20:54
    \$\begingroup\$ Pretty sure that the C operator / would perform fairly well. \$\endgroup\$
    – Eugene Sh.
    Dec 14, 2020 at 21:00
  • \$\begingroup\$ @StarCat Fastest means, "takes the least clock cycles" on this processor, and consumes less than 5K bytes of flash memory to hold the code and any associated tables. There might always be some (yet unknown) faster algorithm out there. I am just asking for people to give the fastest algorithms they know of for this processor architecture. The algorithms put out by Atmel in their application notes take either 243 cycles, or 173 cycles. I was able to improve on this and get it down to 68 cycles. If someone finds a way to save clock cycles in my existing code, that also counts as an answer. \$\endgroup\$
    – user4574
    Dec 14, 2020 at 21:14
  • \$\begingroup\$ @EugeneSh. Pretty sure it wouldn't be compared to this, but is this code the absolute fastest possible? I doubt it - need to take a closer look! \$\endgroup\$ Dec 14, 2020 at 21:16
    \$\begingroup\$ Surely a "fastest possible" claim needs a formal proof. \$\endgroup\$
    – Eugene Sh.
    Dec 14, 2020 at 21:19
This question has been re-asked on Code Review@SE. From that post:
I am looking for ways to reduce either the code size, lookup table size, or number of clock cycles.
From my assessment, access to R1H_TBL(table of high bytes of reciprocals) & R2_TBL[x] is on the critical path, making it less attractive to go beyond investing a single cycle to "special case away" the upper half of R1H_TBL.
R1L_TBL is off the critical path, adding to the annoyance of not seeing how to shrink it - I invested hours on end trying to do polynomial approximation using arithmetic of an 8-bit processor.
Would you believe half the integers are even?
When \$e = 2h, h \in ℕ\$, \$\lfloor\frac{2^{16}}{e}\rfloor\$ = \$\lfloor\frac{\lfloor\frac{2^{16}}{h}\rfloor}{2}\rfloor\$: no need for entries for even numbers!
Not done working out the details (esp carry from high to low byte) or checking applicability to R2_TBL.
I stumbled upon this re-assessing unrolled shift-and-"subtract" (before: 88 cycles "+ return", after ~77, going for 70) after finding I tackled shaving off iterations the wrong way. (The more successful way is using a table for small divisors - and a single comparison deciding what is small.)
  • \$\begingroup\$ I was able to get down to 62 cycles so far. By re-arranging some registers I was able to use the MOVW instructions to move some register pairs in 1 clock cycle. The instruction set reference shows 2 cycles for MOVW, but the part data-sheet shows 1. Also generating the table into RAM allows 2-cycle table access instead of 3-cycles for LPM. This part has a lot of RAM so using 256*3 bytes of RAM is doable. \$\endgroup\$
    – user4574
    Feb 26, 2021 at 19:47
  • \$\begingroup\$ (@user4574: Currently, I'm afraid the above doesn't lead to another viable reduction of table size - haven't found a way to do the necessary "scalings" fast enough. Can you recommend a presentation of Goldschmidt's division & Newton-Raphson for non-floating-point representations? (I (re-)discovered Even/Seidel/Ferguson: A parametric error analysis of Goldschmidt’s division algorithm.) Is there some publicly accessible material your code is based on?) \$\endgroup\$
    – greybeard
    Feb 27, 2021 at 6:57
  • \$\begingroup\$ My approach to developing the algorithm was to look up division algorithms on Wikipedia to get general ideas. en.wikipedia.org/wiki/Division_algorithm . And to look at any recommendations from Atmel (which I liked in the original post). I don't actually know of any good papers I could recommend. Although, it should be noted that with the existing tables you get 8-bit x 8-bit division almost for free if you were writing that function. \$\endgroup\$
    – user4574
    Feb 27, 2021 at 23:28
