Okay so this is a two part question. First Question is probably more of an ELI5 question. But I am a fairly experienced electrician (NOT AN ENGINEER mind you.) but I have a generally good working understanding of electrical theory, ohm's law, grounding, neutrals, etc. But I got asked this question today and didn't really have a great answer. I ask for the ELI5 explanation mainly because those are the explanations I have to give to the junior electricians all day.
To elaborate/illustrate a little though, say you have a stereotypical residential shared neutral circuit, properly wired; we use a two-pole, 120/240V 20A breaker in a 120/240 volt panel. Our hots are of course on different phases. for simplicity's sake we'll say the circuit is stupidly simple, and we have each hot go out to a single identical load, we'll say load A and load B, the same distance away from the panel. My wonderment is basically, why do the loads get nearly exactly 120volts? I mean there is still somewhat of a 240 volt circuit there, starting at one pole, going to load A, out of load A along the neutral, to wherever the neutrals branch off each other to the neutral terminal of load B, out of Load B along the hot and to the other pole of the breaker. (really wish I could draw this, lol). And to my understanding, current travels not just on the path of least resistance, but on multiple paths proportionate to the resistance of the paths available. So, hypothetically, though you've provided a neutral path for each load, why is there no voltage applied across the loads via the hots?
...Actually, In writing this question I feel like I may have generated my own answer: is it the resistance of the load of the other circuit that acts as a choke and causes the current to stay within the wiring of the intended circuits? Or something else?
Second Question! Why/how do the currents cancel eachother out on the neutral. What is happening inside that wire nut, (or other splice point) Are the electrons from one neutral coming down (I speak of this only as a snapshot of the circuit during a single moment in time. I know AC alternates.) from a load smashing into the electrons trying to move up toward the other load? What's happening inside the neutral bar of a 3 phase panel? is it just subatomic chaos in there?
Any elucidation offered is much appreciated?
