I am trying to use a common ground to enable a regulated output across the circuit, however as you can see the SCRs and Bridge use the common earth to relay the positive channel in the bus..
Is this the common pattern of connecting this or is there a more stable circuit which could be used?
enter image description here Thanks.
This is a perfectly ordinary half controlled bridge. It's only drawback is the amount of noise generated in switching the thyristors.
It is a common way of controlling the amount of DC power delivered by a rectifier. Regulation is accomplished by varying the firing angle of the thyristors.
  • \$\begingroup\$ Thanks. What would be the best type of EMC Filtration? and where would you put it? \$\endgroup\$
    – Hightower
    Dec 15, 2020 at 21:49
  • \$\begingroup\$ Unfortunately this is not a blog. If you have more questions please feel free to post them as another question. \$\endgroup\$
    – RoyC
    Dec 16, 2020 at 18:48
