I am trying to identify what I think is a varistor. The markings are : "9 / MVG" and "10K431".
I think "10" is the diameter, "K" is the tolerance and "431" is voltage. Am I correct?
What does "9 / MVG" mean?
In reference to the the following sample part, how do I find out the "Clamping voltage", "Amperage" and "Capacitance" for the varistor I need to replace?
A sample part from RS:
Vishay VDRS - E Series Metal Oxide Varistor 140pF 10A, Clamping 710V, Varistor 430V RS Stock No.178-071 Mfr. Part No.VDRS07H275BSE
The PCB I am trying to fix comes from a Fellowes 225i shredder.
Damaged component
Your Varistor is a MYG-10K431.
The nomenclature that comes before the 'MYG', refers to the manufacturer, if I'm not mistaken.
The MYG-10K431 datasheet expose that:
Part Number Code: MYG-XXKXXX, wherein
  • MYG : Product Type [9/MYG]
  • XX : Diameter [05= 5mm; 07= 7mm; 10=10mm; 14=14mm; 20=20mm]
  • K : Tolerance [K: (+ or -) 10%]
  • XXXX: Voltage
So, I guess 9/MYG means the varistor type. Check the datasheet in the link bellow.
Source [DATASHEET]: https://datasheetspdf.com/pdf-file/1213341/ETC/MYG-10K431/1
  • \$\begingroup\$ Thank you very much. \$\endgroup\$
    – David Fear
    Commented Dec 17, 2020 at 20:30
