I have a problem with understanding the whole feedback business in BJT power amplifier. So far, I only considered it in terms of thermal stability and \$β\$ uncertainty in simple 1-staged amps and was quite comfortable with it but now - in a full power amp - I fail.
Anyway, here's my problem. I do not know how to calculate the value of \$R2\$. The goal is to design a power amp that could produce \$5W\$ onto a \$8 Ohm\$ speaker at maximum input \$1V_{pp}\$. I did, however, established some value of \$R2\$ resistor but only using a real-time simulation (It was a blind adjusting, looking at the oscilloscope)
My calculation method is this:
For a \$5W\$ at \$8 Ohm\$ I need about \$6.5V_{RMS}\$ so \$18V_{pp}\$ => power supply of \$24V\$ should do it.
At the maximum level, the A point voltage sits at around \$22.4V\$.
Assuming that T2s \$β\$ = \$1000\$, the \$R3\$ has to deliver \$1.125mA\$ so:
$$ R3=\frac{(24V-22,4V)}{1.125mA}=1422 \longrightarrow 1,5k $$
Now, at quiescent state, A point voltage sits at \$13.2V\$ so current must be:
$$ I_q=\frac{(24V-13.2V)}{R3}=7.2mA $$
Now, that gives me \$I_b\$ of \$T1\$ transistor (assuming \$β=100\$)
$$ I_b=\frac{I_q}{β}=72µA $$
To achieve this current I calculate R1 (\$V\$ at B point = \$12V\$):
$$ R1 = \frac{\frac{24V}{2}-0.65V}{I_b} \longrightarrow R1=160k $$
And that's it, I have no idea how to proceed on calculating (not blind shooting) the \$R2\$ value when input is +/-\$0.5V\$. Also, I don't seem to understand how to calculate the open-loop gain.
Yes, I have multiple books with formulas but.. well, it doesn't help.
Could somebody please help me sort that out? I am a pure hobbyist so there is no teacher to talk to...
P.S. Forgive the battery biasing Darlingtons - that's just for simplification
