I am designing 3 SPI slave devices that are fairly far away from the host, The SPI communicates at 50MHz (Max) at 3.3v
Slave 3 is an off board device where it is connected to the board by a ribbon cable. The slave devices are just straight up connected to the master exempt for slave 3 which have a tvs diode.
Does the SPI bus needs special attention? is it okay to just straight up connect them ?
    \$\begingroup\$ You may have to run Slave 3 at a lower speed off a separate SPI bus. \$\endgroup\$
    – user16324
    Commented Dec 18, 2020 at 14:56
    \$\begingroup\$ You will want terminations \$\endgroup\$
    – DKNguyen
    \$\begingroup\$ Is it possible to extend LVDS and SPI to 3 meter distance - this might help you understand the problem with bidirectional SPI - if the slaves are not transmitting back then it will be a lot more reliable. \$\endgroup\$
    Commented Dec 18, 2020 at 14:57
  • \$\begingroup\$ @BrianDrummond sadly there is only 1 SPI bus, if it actually has a problem running at that speed, i will just have to keep switching the SPI clock when trying to communicate with slave 3. \$\endgroup\$
    – Jake quin
    Commented Dec 18, 2020 at 15:34
    \$\begingroup\$ One thing you can do to help the termination nightmare is to route that net as a single line rather than a trident with three different length stubs, even if that line is a little longer. (Then you might find a series termination RIGHT at the send end of each line is enough). But I doubt that's good enough for 50MHz. \$\endgroup\$
    – user16324
    Commented Dec 18, 2020 at 15:59
In my case a SPI connection (initially separate loose wires) did not work reliably until I noticed that the clock lead really "likes to be" near the ground lead - suddenly starts working much better. But it was a slightly larger distance, about 30 cm wires between the two separate PCBs.
In response, I have used the ribbon cable with every second wire grounded, and all four SPI signals in between. The connectivity is now reliable. Maybe I have over tried with the measure so draconian but at least one less thing to worry about in my design.
  • \$\begingroup\$ At what speed? for comparison with the question's 50MHz. \$\endgroup\$
    – user16324
    Commented Dec 19, 2020 at 0:48
  • \$\begingroup\$ The speed was irregular in my case, because I was driving all signals directly from C++ on Linux through GPIO in userspace. The tlc5947 chip is kind of SPI but not completely. See electronics.stackexchange.com/questions/520886/… on that project. \$\endgroup\$
    – h22
    Commented Dec 21, 2020 at 20:28
