I've made a 6-bit counter with 6 JK flip-flops that can count from 1 to 33. After it reaches 33, the circuit will go back to zero. I want the circuit to produce a sound when the counter reaches 33. I tried using SPEAKER and AUDIO SIGNAL GENERATOR but they don't seem to work with logic gates. Is there any way to solve this without using Arduino and scripting stuff?
Here is the circuit:
  • \$\begingroup\$ FPGA? What type of sound? A square wave is simplest but has a buzzy sound. \$\endgroup\$ – Mattman944 Dec 19 '20 at 3:50
  • \$\begingroup\$ How fast does your counter count? One step every second or a thousand steps every second? Please show us a circuit diagram (even if it doesn't work). \$\endgroup\$ – AJN Dec 19 '20 at 5:00
  • \$\begingroup\$ @Mattman944 I use the .wav extension for the beep sound \$\endgroup\$ – Rafly Yanuar Dec 19 '20 at 5:41
  • \$\begingroup\$ @AJN I don't know how to check the speed of my counter. It counts only when the count button is pressed \$\endgroup\$ – Rafly Yanuar Dec 19 '20 at 5:42
