7
What component is this? They have a temperature printed, and a part code, but both are pretty much erased in the purple part. The orange one is a bit more readable, but not much. I think they may be resistors, but I'm not sure.
Unknown components
This is the information I can read from both parts:
  • Orange: T1 = 169 °C; D167PHMP
  • Purple: 184 °C
The measured resistance on both seems to be about 3-5 Ω.
Those are thermal fuses. They break the connection permanently once a certain temperature is reached to protect devices from overheating and possibly causing fire.
  • \$\begingroup\$ Oh! Thank you! Nice to have around, then... \$\endgroup\$
    – xOneca
    Dec 20, 2020 at 23:22
  • 4
    \$\begingroup\$ Is there a general reason for the U bend? Like thermal expansion or something like that or it just happen to be this way for unknown circuit specific reasons (geometric constraint...) \$\endgroup\$ Dec 21, 2020 at 5:59
    \$\begingroup\$ @SredniVashtar They don't come like that when new so most likely it's application specific, being shaped like that to fit inside some kind of retention in the device. \$\endgroup\$ Dec 21, 2020 at 14:05
    \$\begingroup\$ Maybe the thermal fuse had to be touching a certain part of the device (like in an electrical heating plate, they sometime touche the plates), to make them as useful as possible. \$\endgroup\$
    – lalala
    Dec 21, 2020 at 18:51
    \$\begingroup\$ Notice how the connection is crimped rather than soldered, to avoid opening the fuse before it has even been used. \$\endgroup\$ Dec 21, 2020 at 19:49
