I am designing a circuit board that will use a 2.4GHz SMD chip antenna from Molex. I am a n00b/amateur at PCB design so forgive my ignorance - does it work nearly the same as how a PCB antenna works?
I have spent quite a while trying to dig through the datasheet for the Molex SMD 47948 chip antenna (details here) but I cannot make much sense of how to use it.
Is this the correct way to use it? I've used PCB trace antennas in the past and they work perfectly. However, with PCB antennas, usually they have two connections, signal and GND as two inputs going into the antenna trace. But with this chip antenna it only seems to have a single input? Do I also need to connect the trace going into the antenna to ground as well?
