Recently I have learned that in buck or boost converters, the output voltage depends only on the duty cycle and input voltage in continuous conduction mode or when current is continuous. However, in discontinuous mode another parameter is added which is the load. Is there a formula that represents the output voltage of a buck or boost converter in discontinuous mode? I just want to see if there is a mathematical representation of how that loading affects the output voltage.
Reference of the formulas I have. By the way I could not get my MathJax to work. I've tried literally copying the inline notations from the tutorial and it doesn't work. Hope someone could edit it for me, thanks.
Output Voltage in Continuous Mode
\$ V_o = MV_{in} \$
\$ V_o \$ - Output Voltage
\$ M \$ - Voltage Conversion Ratio
\$ V_{in} \$ - Input Voltage
Voltage Conversion Ratio for Buck Converter
\$ M = DV \$
\$ D \$ - Duty Cycle
Voltage Conversion Ratio for Boost Converter
\$ M = \frac{1}{1 - D} \$
  • \$\begingroup\$ \$V_0\$ = \$V_0\$. This website has the voltage transfer equation derivation for a boost converter in DCM if that's what you are looking for. \$\endgroup\$
    Dec 22, 2020 at 10:32
  • \$\begingroup\$ "Nondiscontinuous" would be continuous mode. On this site, you have to use backslashes before the $s; reportedly because engineers need to talk about prices a lot. I disagree, and think that we use mathjax way more often than talking about prices on here especially with the ban on product recommendations, but that's what they said and it's too late to change it now. \$\endgroup\$
    – Hearth
    Dec 22, 2020 at 16:11
  • \$\begingroup\$ Oh that would be my mistake. It is meant to be discontinuous mode. \$\endgroup\$
    – AndroidV11
    Dec 22, 2020 at 16:12
Is there a formula that represents the output voltage of a buck \$\color{red}{\boxed{\text{or}}}\$ boost converter in discontinuous mode?
The short answer for a boost converter is this: \$\dfrac{V_{OUT}}{V_{IN}} = \dfrac{1}{2} + \sqrt{\dfrac{1}{4} + \dfrac{D^2\cdot R_{LOAD}}{2\cdot L\cdot F_{SW}}}\$
  • \$D\$ is duty cycle
  • \$L\$ is inductance
  • \$F_{SW}\$ is the switching frequency
Long answer:
For a boost converter, the \$\color{red}{\text{discontinuous}}\$ mode switching cycle comprises three sections: -
  • Charge the inductor with energy
  • Transfer that energy to the load
  • Hold until the next cycle begins (this happens only in discontinuous mode)
If the load current increases, the energy to be transferred needs to increase in order to keep the output voltage constant. This is done by continually sensing the output voltage and adjusting the duty cycle (charge time relative to the whole switching cycle time) if the voltage changes. Duty cycle dictates how much energy needs to be stored and transferred.
To get to the equation at the top you have to start by working out how much "magnetic" power needs to be transferred to the load and this may not be as obvious as you first think.
For instance, you might want Vout to be 16 volts feeding a 5 Ω load and, your input supply (Vin) might be 12 volts. Therefore, the load power is 16²/5 = 51.2 watts. However, that isn't the power that needs to be transferred via the inductor's energy storage mechanism.
In fact, the inductor only needs to "uplift" Vout from 12 volts to 16 volts (Δ 4 volts) hence, the uplift power is somewhat smaller. If we calculate load current (16/5), we get 3.2 amps therefore, the inductor's power-uplift is only 4 volts x 3.2 amps = 12.8 watts.
In the real world we would add-on a few watts for diode forward conduction losses. I'm going to ignore this because, any decent boost-converter will raise its duty cycle (D) to accommodate diode losses. In other words, I can assume that the control loop will do what it needs to do.
So using the "uplift" power calculated from above, the energy (W or work) to be transferred per switching cycle is that power divided by switching frequency \$F_{SW}\$. We can then use the well-know inductor energy formula: -
$$W = \dfrac{L\cdot I^2}{2}$$
From this we can calculate how much current (\$I_{PK}\$) needs to flow into the inductor: -
$$I_{PK} = \sqrt{\dfrac{2\cdot W}{L}}$$
We can then use this well-known formula: -
$$V = L\cdot \dfrac{di}{dt}$$
We can re-arrange it like this: -
$$t_1 = \dfrac{L\cdot I_{PK}}{V_{IN}}$$
Parameter \$t_1\$ is the charge time and duty cycle, \$D = t_1\cdot F_{SW}\$
Summarising the above we get this: -
$$D = \dfrac{1}{V_{IN}}\cdot\sqrt{2\cdot L\cdot F_{SW}\cdot P_{UPLIFT}}$$
This can also be rewritten as: -
$$D = \dfrac{1}{V_{IN}}\cdot\sqrt{\dfrac{2\cdot L\cdot F_{SW}\cdot (V_{OUT}-V_{IN})}{R_{LOAD}}}$$
To get towards the formula at the top needs a little math manipulation using the formula immediately above: -
$$\dfrac{D^2\cdot V_{IN}^2\cdot R_{LOAD}}{2\cdot L\cdot F_{SW}} = V_{OUT}\cdot(V_{OUT}- V_{IN})$$
This can be turned into a quadratic equation: -
$$\dfrac{D^2\cdot R_{LOAD}}{2\cdot L\cdot F_{SW}} = \dfrac{V_{OUT}^2}{V_{IN}^2} - \dfrac{V_{OUT}}{V_{IN}}$$
Which has a solution as shown at the top of the page: -
$$\dfrac{V_{OUT}}{V_{IN}} = \dfrac{1}{2} + \sqrt{\dfrac{1}{4} + \dfrac{D^2\cdot R_{LOAD}}{2\cdot L\cdot F_{SW}}}$$
Picture and formulas from this site. There is also a calculator like this: -
