I know that there has already been question about optimizing PNP turn-off time, but my circuit is a bit different from that question so the solution presented there does not seem to work for me. Here is my circuit enter image description here
I use MAX7219 to drive this circuit. The MAX7219 digit output is inverted by CD4069 so it can drive the common anode 7 segment that I have. D1 represents segment A, D2 represents segment B, this configuration continues up until segment G.
The problem that I have now is because MAX7219 scanning time is at about 800Hz for 8 Digits display, the PNP 2N3906 does not turn off fast enough, so there is ghosting on the display. Here I have tried measuring the 2n3906 collector voltage on CH-1 (yellow), and base input of the 2n3906 on CH-2 (green). enter image description here
From those measurements i think that my turn off delay time of my pnp is way to slow, but i dont know how can i possibly improve it.
Here is the 7 segment that I use: enter image description here
EDIT:
Here is the output waveform of MAX7219 on Digit 1 and Digit 2. From what I see in the datasheet the interdigit blanking should be at least 1/32 of a cycle, but here I see almost no interdigit blanking. Any idea why?
EDIT2:
Here is the waveform of the current measurement on a segment as suggested by Spehro, the current looks fine to me. So it should be eliminate pnp turn off time as the cause of the ghosting problem right?
    \$\begingroup\$ Try repositioning R2 so that it attaches directly to the base of Q2. It's worth a try if you can easily do it. \$\endgroup\$
    Commented Dec 22, 2020 at 10:24
  • \$\begingroup\$ Yeah, I agree with @Andyaka. But there is a little caveat here, R3 should be less than R2 otherwise the voltage divider rule would mean that the base would have a very weak drive. \$\endgroup\$
    – paki eng
    Commented Dec 22, 2020 at 10:27
  • \$\begingroup\$ @AbdullahBaig Should I change the R2 to 10k? \$\endgroup\$
    – shafiyyah
    Commented Dec 22, 2020 at 10:40
  • \$\begingroup\$ Shift the R2 to the base of the transistor. R2 = 10k, R3 = 2.2k \$\endgroup\$
    – paki eng
    Commented Dec 22, 2020 at 10:44
  • \$\begingroup\$ Okay I will try that and report here later \$\endgroup\$
    – shafiyyah
    Commented Dec 22, 2020 at 10:46
You would be better to measure the current through the 330 ohm resistors than the voltage- the current translates into light emitted whereas the voltage doesn't mean much once the LED current drops to near zero.
As well as moving the resistors as others have suggested, I suggest trying to digitally reduce the brightness from full to maybe 80-90% which will increase the interdigit blanking time by a factor of 4 to 6.
You could also replace the BJTs with MOSFETs 2N7000/BSS84 for a large increase in switching speed.
  • \$\begingroup\$ I don't think the using a BJT instead of a MOSFET is the problem here. The speeds OP is talking about, 800 Hz are well within the switching speed of 2N3906 and 2N2222. \$\endgroup\$
    – paki eng
    Commented Dec 22, 2020 at 11:04
  • \$\begingroup\$ @AbdullahBaig The interdigit blanking time is only 5usec nominal (could be shorter), which is short enough to cause problems with the BJT. \$\endgroup\$ Commented Dec 22, 2020 at 11:06
  • \$\begingroup\$ 5 usec is really a tight time for 2N3904 and 2N2222, but sorry I couldn't get your reference to interdigit blanking time. How is that relevant here? I think the significant time is when one digit is displaying, so the others must remain off. And that happens 800 times a second. \$\endgroup\$
    – paki eng
    Commented Dec 22, 2020 at 11:16
  • \$\begingroup\$ @AbdullahBaig There is only 5usec for the digit to turn off at 100% brightness or it will 'see' segments from the next digit. Refer to the datasheet for the MAX7219. \$\endgroup\$ Commented Dec 22, 2020 at 11:43
  • \$\begingroup\$ I will check the datasheet, but I would like to keep in mind that "seeing" is itself not much faster than about 40 ms. \$\endgroup\$
    – paki eng
    Commented Dec 22, 2020 at 11:56
Turns out after some reading on the documentation and application notes of MAX7219, I found out that my Rset for the MAX7219 was too low, because I am driving the 7segment led using external driver. I have tried changing it to 60kOhm (the recommended value was 47kOhm, but because I have 60k lying around I just tried that one) and the ghosting on other 7 segment is completely gone. I have not been able to measure the signal output on the pnp again, but I will give some updates later.
