Full-Bridge resonant converter circuit:
Each transistor (Mosfet) has its own driver (ISO5852S).
I assumed that a full bridge could be controlled with two PWMs.
PWM1A, PWM1B, PWM2A, PWM2B.
Each PWM, at its own time step, drives two transistors.
The driver has both inverted and non-inverted inputs, so we can protect the system from through-current in the event of a PWM failure.
I have also seen circuits where 4 separate PWMs are used to control the FULL-Bridge. (PWM1, PWM2, PWM3, PWM4), with A, B outputs for each.
It turns out that in the case of 2 PWMs, only two groups of transistors can be controlled separately. And in the case of 4 PWMs - each transistor separately.
Question:
  1. Why are 4 PWMs used instead of 2 to control Full-Bridge?
  2. What does the separate control of each transistor give?
    \$\begingroup\$ Dead band, phase shift ability, flexibility? \$\endgroup\$
    – winny
    Dec 28 '20 at 11:17
Phase Shifted PWM (PS-PWM) control,Space Vector Modulation (three phase)..., other kinds of switching sequence to those you have in mind.
HiZ control, adjustable dead time on driving side,...
Your app. can be a quasi resonant LLC converter, driven with PS-PWM.
  • \$\begingroup\$ Thank you for your answer! \$\endgroup\$
    – Delta
    Dec 23 '20 at 1:48
