As I work through learning the four topologies of negative feedback, I can't seem to figure out the transimpedance amplifier.
As far as I understand it, I need to consider my input as a current source. The signal input \$i_s\$ is reduced by the feedback network \$K\$ so that the current \$i_{in}\$ entering the internal amplifier is attenuated. Then the internal amplifier \$A_o\$ produces an output voltage \$v_{out}=R_oi_{in}\$. That output voltage is applied to the feedback network \$K\$, which itself produces the output current \$i_f\$ that attenuates the input because of KCL. So far, so good, I think.
What's missing for me is being able to understand how the discrete components in the circuit at right would apply to the block diagram at left. I was able to perform this type of analysis for the voltage amplifier (common-collector here) and transconductance amplifier (common emitter with degeneration here).
For this example, where would I begin if I wanted to derive the open-loop gain and closed-loop gain in terms of actual circuit values? How does \$R_C\$ in the schematic relate to \$R_o\$ in the block diagram? How does \$R_F\$ in the schematic relate to \$K\$ in the block diagram?
