Background
I'm currently digging into STM32L0 series and I stumbled something I couldn't answer. According the the datasheet page 58 we can see all the peripherals are clumped into a section of 512 MB, now in that section the IOPORT bus resides, this bus handles all the GPIO ports according to page 56.
According to the vendor software each PORT is offset by 0x0000 0400 starting from 0x5000 0000 being PORTA 0x5000 0400 being PORTB and so on.. I tried looking through the compiled memory map and register view, but didn't get any smarter.
Question
Why does each port(A,B,C,D,E,H) have 1 kB allocated, when according to the datasheet/vendor provided SW they only have 11 x 32bit registers associated with them adding up to 44 bytes?
What could this be - Am I completely off ?
typedef struct
__IO uint32_t MODER; /*!< GPIO port mode register, Address offset: 0x00
__IO uint32_t OTYPER; /*!< GPIO port output type register, Address offset: 0x04
__IO uint32_t OSPEEDR; /*!< GPIO port output speed register, Address offset: 0x08
__IO uint32_t PUPDR; /*!< GPIO port pull-up/pull-down register, Address offset: 0x0C
__IO uint32_t IDR; /*!< GPIO port input data register, Address offset: 0x10
__IO uint32_t ODR; /*!< GPIO port output data register, Address offset: 0x14
__IO uint32_t BSRR; /*!< GPIO port bit set/reset registerBSRR, Address offset: 0x18
__IO uint32_t LCKR; /*!< GPIO port configuration lock register, Address offset: 0x1C
__IO uint32_t AFR[2]; /*!< GPIO alternate function register, Address offset: 0x20-0x24
__IO uint32_t BRR; /*!< GPIO bit reset register, Address offset: 0x28
}GPIO_TypeDef;
