I downloaded a footprint for one IC from the internet.
It contained a .kicad_mod and a STEP file.
I have a directory where my project lives, so inside there are .pcb, .pro, .sch file and so on....
When i imported the library for my new foorprint, the new footprint's location is in a different directory of where my project lives..
Considering i will send my files to a board house for pcb fabrication, should i place my custom footprint inside the folder where my project lives? Or it doesn't matter where my footprint is located, and i can send them my files normally?
The board house is not interested in footprint files, they need either Gerber data from the "Plot" function or the .kicad_pcb board file, which contains copies of all footprints used, as you can modify them after placement (e.g. moving a silkscreen text that conflicts with another component).
Therefore, save these wherever it makes the most sense for you. Some people prefer the project directory, some keep a personal library that is common to all their projects.
First of all, the above answer saying the PCB fab won't care is correct. But you should care for your own sanity, as you will have a large number of files to manage before long.
You can configure the footprints / models directory in several places
Go to Kicad main screen. Open your project.
Option (1) Menu->Preferences->Configure-Paths you can see where the modules and packages live. You can add your stuff there but not sure whether Kicad will blow it away if you upgrade the standard kit.
Option (2)
Menu->Preferences->Manage-Footprint-Libraries
Note 2 tabs: "Global Libraries" and "Project Specific Libraries".
At the bottom of the screen, under "Path Substitutions", you can alter
${KIPRJMOD} (project specific models) ... THIS may be one to change
${KISYS3DMOD} (models) ... don't change this
${KISYSMOD} (footprints) ... don't change this
Also! In each model, you can also use relative paths. So if you have a folder with models, whether or not project specific, the model can refer to a relative path to a "./models" subfolder where you can keep your STEP files etc
You can edit the text file directly, or in the Footprint Editor:
open your footprint
Menu->Edit->Footprint-Properties
click on 3D-Settings tab
note your 3D model path probably begins with ${KIPRJMOD} defined above ... then you can define relative path to the file here...
e.g. how I have it: ${KIPRJMOD}/_footprints/_models/foo-bar-1234.step
Not sure if this is the best way to go. Note that this is project specific, but the files stay with your project which is helpful if you just want to zip it up and go. On the other hand, if you fix a bug in the footprint, it won't propagate to other models if you're doing it like this, so do use caution. If you are reusing the part, you may want to set up a common library, or better yet, upload it to KiCad so that everyone can use it.
