Following is the Verilog code for a 4-bit unsigned up counter with asynchronous clear as shown in ASIC.CO.IN:
module counter (clk, clr, q);
input        clk, clr;
output [3:0] q;
reg    [3:0] tmp;
always @(posedge clk or posedge clr)
begin
   if (clr)
      tmp <= 4’b0000;
   else
      tmp <= tmp + 1’b1;
end
   assign q = tmp;
endmodule
Can I define the output as reg and write the verilog as following?:
input        clk, clr;
output [3:0] q;
reg    [3:0] q;
begin
   if (clr)
      q<= 4’b0000;
   else
      q<= q+ 1’b1;
end
endmodule
As I see this, there is no difference between those two codes, am I wrong?
  • \$\begingroup\$ Yes, they are equivalent. \$\endgroup\$
    – Light
    Dec 25 '20 at 8:23
There is no difference in the two examples you wrote. You can even make is simpler:
module counter (
  input  wire clk, clr,
  output reg [3:0] q
begin
   if (clr)
      q<= 4'b0000;
   else
      q<= q+ 1'b1;
end
endmodule
If it is anything like VHDL older than VHDL 2008, it is because you cannot read an output (you can only write to an output), and performing something like q<=q+1 requires you to read q.
  • \$\begingroup\$ please check the following, which is the Verilog code for flip-flop with a positive-edge clock. module flop (clk, d, q); input clk, d; output q; reg q; always @(posedge clk) begin q <= d; end endmodule as you can see, output as register can be written \$\endgroup\$
    – Zohar
    Dec 25 '20 at 8:40
