I'm looking for help identifying a SOD-123 packaged Zener diode with WG G0 marking like the one in the photo. The board has quite a few of these with one of them completely burnt. The closest I've come across is a BZT52C11, but it doesn't quite have the same markings.
Any help is appreciated.
photo of unknown zener diode on a PCB
  • \$\begingroup\$ Spend some time figuring out their role. \$\endgroup\$ Dec 26, 2020 at 21:22
  • 4
    \$\begingroup\$ If you have quite a few of them, couldn't you just find a working one, pull it off the board, and measure its zener voltage? \$\endgroup\$
    – Hearth
    Dec 26, 2020 at 21:25
It looks like BZT52C11 from Diodes incorporated. The "GO" part is datecode, so it can be different. Look at this datasheet: https://www.diodes.com/assets/Datasheets/ds18004.pdf (page 1 - "Marking information").
BZT52C10 or 11 seems correct, from several manufacturers:
https://smd.yooneed.one/code5747.html
https://www.s-manuals.com/smd/wg
